Arrowspace
Banned
- Joined
- Jan 23, 2015
- Messages
- 186
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 18
- Activity points
- 0
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 ENTITY filter_tb IS END filter_tb; ARCHITECTURE behavior OF filter_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT fir_4tap PORT( Clk : IN std_logic; Xin : IN std_logic_vector(7 downto 0); Yout : OUT std_logic_vector(15 downto 0) ); END COMPONENT; --Inputs signal Clk : std_logic := '0'; signal Xin : std_logic_vector(7 downto 0) := (others => '0'); --Outputs signal Yout : std_logic_vector(15 downto 0); -- Clock period definitions constant Clk_period : time := 20 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: fir_4tap PORT MAP ( Clk => Clk, Xin => Xin, Yout => Yout ); -- Clock process definitions Clk_process :process begin Clk <= '0'; wait for Clk_period/2; Clk <= '1'; wait for Clk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; wait for Clk_period*10; -- insert stimulus here wait; end process; monitor : PROCESS (clk) variable c_str : line; begin if (clk = '1' and clk'event) then write(c_str,Yout); assert false report time'image(now) & ": Current Count Value : " & c_str.all severity note; deallocate(c_str); end if; end PROCESS monitor; END;
ERROR
ERROR:HDLCompiler:377 - "H:/Sequencial_filter/filter_tb.vhd" Line 49: Entity port xin does not match with type std_logic_vector of component port
ERROR:HDLCompiler:377 - "H:/Sequencial_filter/filter_tb.vhd" Line 50: Entity port yout does not match with type std_logic_vector of component port
ERROR:Simulator:777 - Static elaboration of top level VHDL design unit filter_tb in library work failed
