Terminal Block on proteus Library
Gaber Mohamed Boraey
Full Member level 4
Full Member level 4
hello everybody,
just a simple question, is this terminal block exist at the proteus v8.5 software?, as i have looked and only found fewer pins terminal blocks, such as 12 pins, and what i need is 25 pins,
it's a screw terminal block, but what i have found doesn't have screws but only virtual shape,
hoe anyone here help with this simple questions,
and thanks for all in advance
here is the terminal block link, i am talking about the green terminals,
https://www.aliexpress.com/item/IDC...lay-terminal-station-DIN-Rail/2043601916.html
waiting your response
hello any help?
Do you expect all PCB software to have every single part that is available in the world - within it's libraries?
I do not, you should not either.
This is such a simple part that you should have very little problem in making your own footprint for it.
Learn how to make symbols, components and parts, then you will not need to post like this because by the time you have finished writing the post you could have finished the whole part :)
It is not a single 25 pin terminal block on the picture.
It is a 7 pin block and two 9 pin blocks.
Indeed it´s on you what pin_count_configuration you use. Maybe 5 x 5 pins...
Klaus
