Tera Term to send continuous
engr_joni_ee
Advanced Member level 3
I need to send data from PC to COM port continuously which is just a short string to be send every 10 second. Is it possible to write for loops in Tera Term for that purpose ?
A short string every 10s? Why not use a script?
in simplest case just (pseudo code)
copy file --> COMx
pause 10
repeat
Klaus
I guess first I need to setup COM connection in Tera Term and then I need to run the script. How to run the script ? In which file do I need to save the code ?
several OS support several script languages....
To be able to give a detailed answer we need to know your details first.
Klaus
A quick internet search showed that TeraTerm supports a script language (TTL = TeraTermLanguage).
Didn´t go deep thout the infromations, but it seems it can do what you want.
Just do an internet search on your own to find documentation and sample codes ...and everything else you need.
Klaus
I have tired the following Macro code in TTL, it works.
pause 2
val = 0
; Repeat 5 times.
i = 5
do while i>0
    i = i - 1
  random val 100
  send 'ABC'
  pause 1
loop
exit
I am wondering how to mention carriage return line feed. I would like to start new line and cursor in the start of the line.
what about using "sendln" instead of "send".
or try "strspecial"
I found them in the documentation...
There maybe are more suitable commands...
Klaus
