Hi all, i am just want to measure the room temperature using LM35 temp. sensor the pic16f877a will change the state of one of its ports depending on the reading of LM35.
For example: portb is used to switch the pump (fire fighter) on and off when the LM35 reads temp. above 35degree and off when the temp. is below 35 degree.
Thanks
Thanks
I also have the same project, but not built yet. To do this I made a comparison between LM35 and MCP9701 (Microchip temp sensor). I prefer the last sensor due to highest accuracy and better price.
Another point I would like to do is the impedance convertion until ADC pins input (10kΩ). I intend to put an operational amplifier between ADC and temp sensor to convert the impedance of MCP9701 from 20Ω to 10kΩ.
Thanks
Thanks
Hi i'm new to this whole experience i have a project and i'm banging my head on the wall for 4 hours now can someone plz help me:
i have to program a PIC 16f77 on a washing machine program or a part of it i need the code for seting a pin in out doesn't matter whitch one for a watter pump and after for mesuring a temprature of 60 dagrees celsius till that temprature i have to set another pin as the rezistence to the value 1 when the tempreture reaches 60 dagrees the pin from the reistance goes back to 0
the frequencey is 4mhz and the time would be 40 min that's if i;m not mistaking 40*60*4000000=9600000000 instructions plz i really need some help i can't figure it out on my own and sry for the bad english if someone has any idea i could use the help
