Mohammed Odeh
Newbie level 3
I am having a unknown issue while working on my temperature switch project
actually its a small project :
I am using lm35 sensor connecting it to amplifier 741 with a gain of 5 ( my source suply 5V ) , and the connecting from 741 to comparator LM311 ( to V+ ) , and for (V-) of the LM 311 I design small circuit from 15 K and variable resistor 25 K .
the 15 K is connected to source 5v and then to 25 variable resistor ,and the 25 second terminal to the ground .
LM311 is to compare V+ with V- , if V+ > V- that mean ON other wise off .
the problem is on the LM311 part :
for example I am getting 1.36 v on V+ from LM35 and 1.73 from V- ,this mean Off because V- > V+
but actually it is ON until the defference become more like V+ = 1,36 and V- = 2 v .
can any one help me with this issue
Note i try connecting another 741 op amp as a buffer after the first 741 but nothing work .
