See what you mean, the adc routine outputs to the leds not the oled display.
Afraid you cannot just mix and match Assembler and C, so my code is no good for that purpose.
The 18F series is right in the middle of the Pic range, it is equally suitable for programming in Assembler or C.
Having that oled display on the board does mean you have to use it with C for now, although it is quiet possible to add a conventional 16x2 lcd to the expansion port so it could be used with either - so many pic projects are based on a 16x2 lcd.
So you need to decide which programming route you want to follow - can give to some links to some programming books if you want.
