Temperature control by using PIC28f452
mpe_10
Newbie level 6
Newbie level 6
hi...
I have two question to the pic18f452 experts..
1- I'm working on a project about temperature PID controller using PIC18f452 and I'm asking if anybody work on a such project to give some tips and if possible the c algorithm for the pid controller?
2- my second question is about the microcontroller analog output .How can I generate an analog signal from the microcontroller to control the proportional valve?
before I end this post, i want ask you about a book which is "Embedded Design with the PIC18F452". Could I get this book free online
You can use a DAC (digital to analog converter).
Also, if the automation loop time is sufficiently long you can use a pwm output from the microcontroller, followed by a low pass filter, to generate an analog signal.
Thanks lambtron for your response ..
after my search for a dac i found mcp4921 from microchip..
do you have any idea how to program the PIC with the dac in order to get analog signal??
in addition..
could you give a C algorithm for PID controller..
thanks again
mpe_10 said:
... i found mcp4921 from microchip.. do you have any idea how to program the PIC with the dac in order to get analog signal?
Have a look at this **broken link removed**.
There are numerous examples of this on the Internet. For example, see Appendix C of this article.
Dear lambtron...
thank you very much for your help...I really benefit from your posts...
thanks again
