OT: That "line" / is always less clear / I can see the photos of the sine / I do not think cursor / is a "ray of what is returned? I almost trace the channel to a minimum brightness.
That the dotted cursor in the car mód unìkdy "affect" peak-peak values / peak / signal is measured over a bug? They must be over a millimeter, thereby increasing peak-peakp value seems / but I do not know, maybe not / -?? .
Hi nnntomas,
Interesting problem, but I diont have some idea...
Maybe you have more luck at "Tek forum from yahoo"?
I found these "Tek User groups" address ca. 2 years ago, but I dont know if it is working yet...:YahooTEK-Forum! **broken link removed**
Good luck!
K.
Try readjusting the grid bias which seems way to high so the Z amp cannot blank the trace. Set intensity to 10 o'clock and turn grid bias trimpot that trace is visible, not bright.
