confusion
Junior Member level 3
hello!! am learning rtos in my curriculum . i came accross the code below and i dont understand the code flow..as in when the task switch will ocurr and when will the task perform the lcd functions. i don't understand the sequence in which the things will happen .plz help in interpreting what the output of this code will be.
code: priority inversion.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 #include "config.h" #include "stdlib.h" #include<LPC21xx.H> #include<key.h> #include<lcd.h> OS_STK Task1Stack[100]; void Task1(void *pdata); OS_STK Task2Stack[256]; void Task2(void *pdata); static OS_EVENT *semaphorea; static OS_EVENT *semaphoreb; //OS_TASK_CHANGE_PRIO_EN=1; int main (void) { keyinit(); LCDInit(); lcdcmd(0x80); LCDInit(); OSInit(); semaphorea = OSSemCreate(1); //counting semaphore ,1st semaphore semaphoreb = OSSemCreate(1); //2nd semaphore if(semaphorea!=NULL) { DisplayLCD("Sema a create",13); } else { DisplayLCD("Sema a not create",17); } if(semaphoreb!=NULL) { DisplayLCD("Sema b create",13); } else { DisplayLCD("Sema b not create",17); } delay(); clrscreen(); delay(); //DisplayLCD("Key: LCD:"); OSTaskCreate(Task1, (void *)0, &Task1Stack[99], 2); OSTaskCreate(Task2, (void *)0, &Task2Stack[255], 3); OSStart(); return 0; } void Task1 (void *data) { int n, i; char err; data = data; while(1) { OSSemPend(semaphorea, 1, &err); clrscreen(); DisplayLCD("task1:sem a taken",17); for(i=0;i<900000;i++); for(i=0;i<900000;i++); for(i=0;i<900000;i++); OSTimeDly(100); OSSemPend(semaphoreb, 1, &err); OSTimeDly(100); OSSemPost(semaphorea); OSSemPost(semaphoreb); } } void Task2 (void *data) { int n,i; char err; data = data; while(1) { OSSemPend(semaphoreb, 1, &err); clrscreen(); DisplayLCD("Task2:Sem b Taken",17); for(i=0;i<900000;i++); for(i=0;i<900000;i++); for(i=0;i<900000;i++); // OSTimeDly(100); clrscreen(); DisplayLCD("priority",8); OSTaskChangePrio(3,1); OSSemPend(semaphorea, 1, &err); clrscreen(); DisplayLCD("task2:sem a take",17); OSTimeDly(100); OSSemPost(semaphoreb); OSSemPost(semaphorea); } }
