worldsheep
Newbie level 2
As the title states, I have a problem in the visualization of drill holes in target3001. All holes looked normal untill I generated the Gerber files. Now all holes are displayed as stars and i don't understand why. Closing and Opening target3001 doesn't solve the problem. Additionally, if I open a old project, all the holes are showed as stars. Has anyone already had this problem before?
When look at the 3D view all holes are normal.
I solved the problem. When you try to print a PCB you can choose "holes as pictograms". If you tick this option and then print or cancel and save, then all holes in your PCB will look like stars. Not only in the printed file but in all your projects.
To solve the problem just go to "print", untick that option and save.
:fight:
:fight:
