eem2am
Banned
tapped buck converter
Hello, i cannot understand why the inductor in the "tapped" buck converter needs to be tapped
...or see page 6 of the following App Note:-
http://www.powerint.com/sites/default/files/PDFFiles/der186.pdf
it seems to me that the inductor between terminals 1 and 4 is not needed?
do readers know why it is there?
thanks in advance
Added after 4 minutes:
also, when the switch is OFF, the current in the inductor between 5 and 6 will be the same as the current in the inductor between 7 and 8 because these have the same number of turns.
....but that would mean there was 350mA flowing in the R1 and R2 which would cause a massive voltage of some 20000 volts across these resistors.
How can this circuit possibly work as this voltage would destroy it?
thanks in advance
