jadnounyah
Member level 1
So I am trying to design a tapered match for a 200 ohm load to a 50 ohm characteristic impedance, and I am supposed to start with quarterwave lines and later reduce the lengths. Now the concept I am aware of the using the same length but different impedances for the tappered match, I was hoping I could be introduced to resources for both varied lengths and impedances for the taper sections for matching. I am using ADS for the design by the way( if it helps anything).
