cupoftea
Advanced Member level 5
Our 24V input to 24V, 2A 150kHz isolated flyback works fine with the primary wound as two layers
of enamelled copper wire. (PQ20/16 bobbin)
Ns/Np = 15/10
The secondary sandwichs the primary with series windings of 8 turns and 7 turns.(triple insulated wire)
The primary 10 turns are comprised of 2 layers of 5 turns (3 strands of 0.315mm ECW) . We just wind 5 turns across the bobbin,
and then the next 5 gets wound over the top of the previous five turns..its so easy to do it like this -there is no tape between these layers.
I believe that if one layer gets a nick in the enamel then we could be taking a big risk doing this.
I believe that we should really have tape between the layers. Though we have had no problems doing it without tape
for some 2 years.
Do you think we should use tape?
Ns/Np = 15/10
for some 2 years.
