dll_fpga
Full Member level 3
- Joined
- Mar 9, 2011
- Messages
- 185
- Helped
- 19
- Reputation
- 38
- Reaction score
- 21
- Trophy points
- 1,298
- Location
- kerala,India
- Activity points
- 2,416
And why would not 200 MHz not be visible with a DSO or logic analyzer? But I digress. Point about frequency noted. But by talking about that "ram module", and the fact that you want a fast write clock a slow read clock, an possibly different read/write bus widths... you have just specified the perfect match for a fifo. So if I understand your design, then yeah you want a fifo there. You can put one together with a few mouse clicks in the core generator...
i had generated a FIFO with independent clock for read and write....now i need to see the output on LED's ,so should i use a switch to give clock for read operation?......(to give a slower clock by pressing the switches so that output is visible on led's)
