[SOLVED] Take different output value from array every clock cycle
Mai89
Junior Member level 2
In this code i have input called IP i want to divide it into sub-parts and each part appear in output (SUb_M) every clock cycle, but after simulation output remains at the same value at every clock cycle (which is the first part)
I need SUb_m to be changed at every clcok cycle.
process (clk, en)
begin
for i in 0 to addi-1 loop
if(clk='1' and clk'event) then
   if(EN='1') then
Sub_M <= w(i);  --- w is an array
end if;[syntax=vhdl][/syntax]
I would have thought you would get a multiple driver warning, but we can't see all of the code. Your problem is you are writing this as software. A FOR loop doesn't loop like software, it's a shortcut for typing. Search for "VHDL FOR LOOPS" and you will find many examples of how to use them. To solve your problem you need to make your own counter that increments every EN='1' cycle and use that to reference the array location.
Reactions: Mai89
    Mai89
bking, you won't get a multiple driver warning, as the VHDL loop is unrolled and only the last assignment Sub_M <= w(addi-1); gets assigned.
OP what you wrote does this.
Code VHDL - [expand]
8
9
10
11
12
process (clk, en)
begin
   if(EN='1') then
      Sub_M <= w(0);
      Sub_M <= w(1);
      Sub_M <= w(addi-3);
      Sub_M <= w(addi-2);
      Sub_M <= w(addi-1);  -- this is the final assignment to Sub_M so it is the  *only* assignment that maters
   end if;
end if;
To output each w in sequence on each clock cycle you want to do something like this.
8
9
10
11
process (clk)  -- en was unnecessary as the process is "clocked"
begin
  if rising_edge(clk) then
    if (en='1') then
      Sub_M <= w(idx);
      idx <= idx +1;
    else
      idx <= 0;  -- clear it when not enabled in lieu of any reset in this code.
    end if;
  end if;
end process;
Reactions: Mai89
    Mai89
