Santa
Member level 4
I am, for the second time, victim of the dumb date protection
in Flexlm attacking you when it thinks the date has been changed
to some past value. This time, I was testing a NTP client and I
really had no way checking if the time would go back or forth when
it adjusts.
Mentor recognizes also that this protection is too much and badly
implemented but does nothing efficient to force Globetrotter to
remove that crap. :x
Mentor just tells you have to verify that you have no file with
dates belonging to the future that may be detected by flexlm.
I tried last time to find them but failed finding any file belonging
to the future and reinstalled the system. This time, I have enough.
Does anybody know :
- Which files are checked :?:
- If the flexlm starts again functioning once the system date gets
higher than the newest file in the system or if it stays blocked
forever. Does it need a reboot?
Thanks for helping. Shame on Mentor for their lack of support
in this issue. If Mentor forces you to use Globetrotter's crap,
it should also be responsible to find a solution. I didn't buy anything
from Globetrotter, only from Mentor, and it must work.
it adjusts.
Does anybody know :
