Tace and Pad SIze failure
thunaivendan
Member level 3
Member level 3
Chennai, Tamil Nadu, India
Hi I done PCB for Higher amps rectifier...I,use default pad,parts,while schematic and routing..after getting from manufacturer pad size..and holes,trace very thinner and smaller..How set a trace size..while using large size for routing its getting bigger and bigger in eagle..but after generate gerber..it reduced to smaller..is any calculations..for trace and drill,pad size..
Tell Me global standrd for trace width...Drill are smaller after generate eagle..what is the procedure..to change drill size..
Whats the Mils calculation
Your message is rather garbled and difficult to understand. Post some files/images to explain it properly.
Mils are thousands of an inch.
Keith
can you tell us the trace width and drill size you used and unit
Hi Thunaivendan,
Values you specified seems to be in inches. Multiply those values by 1000 to convert them to mils.
Trace width is 16 Mil and drill size 23.6Mil.
SHABU
thank u shabu..what is default trace width drill for component,by this value 16mils,23.6mils very thin trace and small size hole..if i taken 6A diode,IRF540 fet what is drill size,i just now i change pad drill in library...for half bridge single phase board fix the trace width
Hi Thunaivendan,
Drill size, pad size should be determined based on the footprint information in datasheet.
Post the part number you are using.There is no specific trace width as standard.It is based on the requirement.
Follow your stackup. For 6A current you need to use solid shape instead of trace.IRF540 seems to be a SMD part not through hole. Post full part number.
SHABU
23.6mil is 0.6mm - rather small for a 6A diode, I would think. If you find the package for your chosen component there is likely to be one in the Eagle libraries. For track widths, if you are conducting high currents there are plenty of current calculators out there - try a quick search.
Keith
