pudding
Member level 2
Hi everyone,
I want to design a T junction power divider from 12GHz to 24GHz. But there is always a resonance peak at about 21GHz. Then I change the length of the arms, the peak can move a little bit according to it. Does anyone can help me to figure it out? I set up one port as 25ohm, and the other two 50ohm so that the resonance does not come from the reflection at the port. Thanks a lot!
