Sythesis of Finite State Machine (FSM)
tariq786
Advanced Member level 2
USA
finite state machine simulator
I have synthesized FSM and data path for a design. When i run the post synthesis gate level Verilog simulation, i get xxxxxxxxx.
I traced the reason and the reason is that in one of the FSM states, i am using "if condition" on an external input (from another module) that does not change in one clock cycle. For example
State_Si:
begin
if(DONE) // DONE (an external signal) takes 10 clock cycles to become true
next_state = State_Sj;
else
next_state = State_Si;
end
So when State_Si is reached the very first time, DONE is neither true nor false. It is unknown. After 10 clock cycles, it becomes 1 and so in these 10 clock cycles, it remains in the state State_Si.
This thing works absolutely fine in pre synthesis behavioral (golden) simulation but does not work after synthesis.
Any ideas how to solve this problem?
Any link or tutorial will be really appreciated.
I hope i made it clear. Let me know if you need more explanation.
Thanks a lot.
unknown states in fsm
i would suggest you to introduce a reset state where you can initially reset all your outputs to 0 and then start the process. this way u can avoid the x and will not have any problem at synthesis
haneet
    tariq786
I have done it in the other always block. That is
always@(posedge clk)
if(reset)
current_state <= 0;
else
current_state <= next_state;
Is this what you mean?
What do you mean reset all your outputs? Are you talking about state flip flops like in the above example or what?
Remember i am talking about controlling an external input whose value determines going to the next state or not.
i meant when u have ur reset make the state_sj=0; along with the other conditions which u mentioned
always@(posedge clk or posedge rst)
being
if(rst)
begin
state_sj<=0;
state_si<=0;
current _state<=....
end
i hope you got what im tryiong to say...
haneet
    tariq786
Let me check and then get back to you.
Thanks again
Added after 5 hours 28 minutes:
No it does not work. States are local parameters in my FSM module and they cannot be put to be equal to 0 as you said i.e.
localparam [5:0] //one hot encoding
S0_INIT = 6'b000001,
S1_FETCH = 6'b000010,
S2_AES = 6'b000100,
S3_CALC = 6'b001000,
S4_WB = 6'b010000,
S5_DONE = 6'b100000;
Tariq hi,
apparently some other logic is driving the DONE signal.
can't you initialize this logic to have DONE=0 during these first
10 cycles. It is not a matter of this FSM, as the other logic
is always giving an x as an input...
Pavlos
    tariq786
tariq can u post the complete code... i guess i will check it frm my end and see wht cld be the problem..
haneet
    tariq786
Haneet. Thanks a lot my friend. I have figured out what was wrong.
Have a good one.
tariq can i also know what was wrong??
    tariq786
Sure. The external signal DONE was getting generated after the current state. So its value in the current state was unknown. I made sure that before the FSM reaches the current state, DONE has a valid value of either 0 or 1.
Hope this helps.
k tariq... all the best....
haneet
    tariq786
