yefj
Advanced Member level 5
Hello,I have tried to create a systick delay using systick interrupt as shown in the code bellow.
But i cant see what is the link between the core frequency and the actual delay of the sistick interrupt.
How can i link the core frequency to the actual delay?
HAL MANUAL STM32FG14
https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.DM00105879.pdf
STM32F407 RM
https://www.st.com/resource/en/refe...-arm-based-32-bit-mcus-stmicroelectronics.pdf
STM32F407 RM
#include "stm32f407xx.h"
volatile uint16_t delay_count=0;
void SysTick_Handler(void)//called every 1ms
if (delay_count>0)
delay_count--;
void delay_ms(uint16_t delay_temp)
delay_count=delay_temp;
while(delay_count){}
int main()
RCC->AHB1ENR|=(1uL<<3); //set thirdbit
//GPIOD->MODER&=~(1uL<<31);//reset 0 on 31 01 to gpio_moder 31,30 bits in register
//GPIOD->MODER|=(1uL<<30);//set 1 on 30 output mode for pin 15 port D
GPIOD->MODER=0x55000000;
SysTick_Config(SystemCoreClock/1000);//1 ms interrupt
GPIOD->OTYPER=0; //all register is push pull
GPIOD->OSPEEDR=0;//speed low
//GPIOD->ODR|=(1<<15); //Sets pin 15
while(1)
GPIOD->BSRR=(1uL<<15);
delay_ms(500);
GPIOD->BSRR=(1uL<<(15+16));
delay_ms(500);
