system input and output
47amadb
Junior Member level 1
pakistan
hello every one:
can any body answer these questions:
1) if the output of the system is greater than the input, what is the device called?give an example? where would we apply such a device in a system?
2) if the output of the system is less than the input, what is the device called? give an example? where would we apply such a device in a system?
thanks and wainting for your answers....
Answer 1 = Amplifier. You use amplifiers to make a desired signal stronger.
Answer 2 = Filter. You use a filter to weak unwanted signals.
