[SOLVED] Synthesize SRAM compiler output in verilog
kyonglee
Newbie level 5
Newbie level 5
Hello,
I am using artisan sram compiler and could get verilog view for my sram. I am trying to synthesize the sram with some glue logic using design compiler, but failed because the verilog code for sram is not synthesizable. I have tried to generate everything that I can generate from the sram compiler, but the only files that might be relevant to design compiler is the verilog code and .lib files.
Is there any way that I can synthesize sram from sram compiler? Any comments and links are good and step by step instructions are better.
Thanks!
1. using library compiler convert lib file to db file
2. add the db file to your dc synthesis scripts, like "set link_library [concat $link_library $your_mem.db]
done !
Thank you!!
I didn't include .v file from my sram compiler but do include .db file.
Design compiler consider my sram as a black box, so there is no sram synthesized in my gate level netlist, but timing report contains sram timing information.
This is exactly what I want.
Thank you!!
%dc_shell> check_design
to check there are any unresolved module, if yes. check your search_path
you need to add Memroy Verilog top module(only input & output port information) to you Design
