skyworld_cy
Junior Member level 3
I'm trying vivado with synplify flow. First I tried full vivado flow and this works fine. Then I tried to transfer all data files to synplify. I read all verilog files and xci files in synplify. All seems ok except some IPs failed. These failed IPs are generated by vivado. I just import these IPs with this command in synplify:
"add_vivado_ip -xci xxxxxx.xci", for example, "add_vivado_ip -xci dds_sine.xci" or "add_vivado_ip -xci dds_sine.xci -upgrade_ip"
At first all IPs are read in synplify with success. But when I press "Run" button, some IPs failed with information like "Reference to underfined module dds_sine_dds_compiler_v6_0_23" whereas this dds compiler I named it as dds_sine. I can't find reason why this failed. Can anybody give me some help? thanks very much.
