Synopsys Primetime constraints issue
fv
Newbie level 1
Newbie level 1
prime time constraints
Hi Group,
I am a new user of Synopsys Primetime. I have a verilog design, on
which timing analysis is to be done. Now I am not aware of the maximum
register to register delay and so I do not understand as to what kind
of clock constraint should I apply. Can primetime analyse the design
and use a default clock or such if I dont give it one.
Thanks,
Fazela
In order to do the static timing analysis(STA), clock definition is the minimum requirement.
Because in PrimeTime, most timing constraints are related to clock.
So, you have to apply the following timing constraint to PT at least,
pt_shell> create_clock -name <clock name> -period <in ns> <clock port/pin>
Give the desired clock period for checking the timing of the netlist.
Then you can run
pt_shell> report_timing
to see the result.
