geconom
Full Member level 3
Last night's solution:
Synopsys has changed its Linux GUI in their latest releases. For those using version 2002-05-SP1 or SP2, Design Vision, Prime Time, CoCentric and other tools use the MainWin library. This works fine with Red Hat 7.2, 7.3 (tested) and as I have heard 8.0 (no news about 9.0). However, when using eXceed from a connected Windows machine, they no longer work because of a missing font (-mainwin-ms_sans_serif-medium-o-normal--13-130-75-75-p-70-iso8859-1 found with error logging enabled) . To overcome this, make a font alias and load it with the eXceed configuration tool.
As an example, this is the alias file I have created and used:
# Mainwin aliases of pseudo font Arial
"--arial-0-0---0-0-0-0-p-0-iso8859-1" <winfont
"-mainwin-ms_sans_serif-medium-o-normal--13-130-75-75-p-70-iso8859-1" "--arial-0-0---0-0-0-0-p-0-iso8859-1"
I hope this helps
I hope this helps
