pokemonstation
Junior Member level 1
Synopsys Hercules
Hi all,
I was trying to run Synopsys Hercule DRC using Hercule VUE (graphical interface) but I encountered a strange error. Here is the complete error log. The error is near the end of the log.
I am not sure what does the error mean. It looks like it might have something to do with OpenAccess. Can anyone lend a hand and take a look at this? I'd much appreciate any help!
Hi all,
Hercules (R) Hierarchical Design Verification, SUN.64 Release B-2008.09.18103 2008/08/21
(C) Copyright 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
2006, 2007, 2008.
Synopsys, Inc. All rights reserved.
Called as: /usr/licensed/synopsys/hercules_B-2008.09/bin/SUN64_58/hercules -vue -b inv1 -p ./ -i test65 -ob OUT -o /n/homeserver2/user2a/mcwang/cadence/out.gds -g group -O GDSII
-s /n/homeserver2/user2a/mcwang/cadence/inv1.cdl -sf cdl /tmp/vue_j4aigI/.VUE_GEN_RUNSET
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:11672: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:11681: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:11690: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:11699: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:11728: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
RUNSET WARNING : /tmp/vue_j4aigI/.VUE_GEN_RUNSET:17359: For one layer EXTERNAL, if FLAG_DISCONNECTED set to FALSE, CHECK_SAME_POLYGON need to be TRUE
Wed May 20 02:59:51 2009
EV_Engine (R) Hierarchical Design Rule Checker, SUN.64 Release B-2008.09.18117 2008/08/28
2006, 2007, 2008.
Running Multi-Threaded code with 2 thread(s)
Runset file ...................... /tmp/vue_j4aigI/.VUE_GEN_RUNSET
Current Directory ................ /n/homeserver2/user2a/mcwang/cadence
Hostname ......................... tombstone.Princeton.EDU
Platform type .................... SUN64_58
GDSII output file name ........... /n/homeserver2/user2a/mcwang/cadence/out.gds
GDSII output_block name .......... OUT
Run details ...................... /n/homeserver2/user2a/mcwang/cadence/run_details
Group file directory ............. /n/homeserver2/user2a/mcwang/cadence/group
Retain group files ............... smart
Check reference structures ....... no
Error in: hoDLopen(/usr/licensed/synopsys/hercules_B-2008.09/lib-u/SUN.64/OA/lib/2.2.6/opt/liboa.so)
#3000-libhost.a (ho_dynlib.c:103) during dlopen(/usr/licensed/synopsys/hercues_B02008.09/lib-u/SUN.64/OA/lib/2.2.6/opt/liboa.so): Id.so.1: ev_engine_mt: fatal: /usr/licensed/synopsys/cadence-20060508/IC613.sun4v/oa_v22.04.038/lib/sunos_58_32/opt/liboaTcl.so: wrong ELF class: ELFCLASS32 (1 times)
