charles_hoho
Newbie level 3
Hi friends,
I got error when I run DFT 2008.9. The command "insert_dft" responds "Invalid test protocol". The old command "inser_scan" is supported.
Run "set_dft_signal" responds "-type not found". What type should I set?
As I know, the Test_Compiler "set_scan_signal" type is "test_scan_enable".
Why it is wrond on DFT_COmpiler?:--(
