Synopsys DC installation problem.
cyc
Member level 1
Member level 1
synopsys installation
Hello,
I install the design compiler 2001.08 in REDHAT 7.2 recently.
A error message shows" Can not find bxxx.so " Sorry, I can't come up with the full file name. I guess I lost some environment setting. Can someone show the the full environment setting such like LD_LIBRARY_PATH or someone else?
Thank you.
cyc
Check old RedHat CD
Hi, cyc
May be you cann't access ftp site.
Please check Redhat 6.xx version cd.
You can find it.
Thanks
I faced the same problem. How do I get it?
Hi Verilog,
I found the .rpm in the RedHat 7.2 CD2 and fixed the problem.
cyc
