Synopsys Custom Designer error
artho
Junior Member level 1
I am designing a inverter with Synopsys Custom Designer and i am getting an error in LVS(Hercules). The Custom Designer console give the follow message:
Error: The job 'hercules_lvs_1' started on host 'localhost' with process id 15073 failed to start or complete successfully; the job's return code is 33.
I can't found a solution for this, and without LVS i can't continue the project.
Thanks!
Artho, ask your administrator to set the environmental path of the hercules. If problem still exist check the binaries of the tool installed.
