Wamor
Junior Member level 2
microcontroller transistor switch
Hello,
Sorry if this topic is posted in the wrong forum.
I've got the following. To switch a load with a microcontroller i use a 2n3904 transistor. The collector of this transistor is connected with a 2k2 resistor to +24V.
The base of the transistor is connected with a 22k resistor to a output of the microcontroller. The emmiter of this transistor is connected to ground.
The microcontroller is giving a 10kHz outputsignal.
When i measure on the collector of the transistor i see a switch-on delay of 1us (microcontroller gives output low/high) and i see a switch-off delay of 2us (micrcontroller gives output high/low). This delay is critical in my application and should be at least in the ns-area. (max 100 ns).
Can anybody give me some information how to improve the switch-on and switch-off delay.
Thank you and best regards,
Wamor
Hello,
Wamor
