nandopg
Full Member level 4
- Joined
- Apr 26, 2001
- Messages
- 205
- Helped
- 8
- Reputation
- 16
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Over the Rainbow
- Activity points
- 2,521
I have to design an off-line switching regulator with the following specs:
Environment: Class C
Input transient protection: for class C environment
Vac input: 90-245V
Vout: +55Vdc +/-1V from no load to full load
Noise: 0.5Vpp at full load
Current: 35A maximum (100%)
Switching Frequency: 25KHz (?)
Efficiency Expected: better than 70%
Conducted-mode noise: better than +80dBu
In general, my choices are:
1- To comply with the conducted-mode noise: A 7 sections lowpass filter at both AC lines. The coils wound on pot-cores and ceramic caps to ground
2- For input transient protection: Gas-filled spark gaps on both AC power lines and AC quick circuit breakers
3- Topology: Full-bridge oscillator tied to a planar non-resonant transformer.
I am looking forward:
1- To have an analysis on the specs above to know if something important was missed.
2- To know if my choice on the oscillator topology and transformer is a good one. Suggestion on alternative topologies
3- To have suggestions as to PNs for switching elements, class of capacitors for the output filter, ferrites, etc...
4- To have some hints regarding constructive aspects.
5- Literature and design/simulation software.
I deeply appreciate any help.
NandoPG
Vac input: 90-245V
NandoPG
