sweethomela8
Member level 4
I'm bringing a board up for the first time, and cannot get an exact amount of current needed on my voltage rail (+3.3V), so I decided to protect myself by getting a switching regulator that can provide up to 10 Amps @ 3.3V.
The data sheet says that the efficiency is about 85 percent if I'm using 2 Amps or more and if I'm using less than that, the efficiency drops to 50% at the lowest.
Will I run into any problems if I go below the 2 Amp consumption point where the efficiency drops to 50%? Or does that simply mean, the regulator dissipates wasted energy as heat?
Thanks.
Thanks.
