Switching problemm in the given T flip flop circuit
rajaram04
Advanced Member level 3
earth
Hello sir
i hv a circuit diagram here which is working properly but switching needs a mechanical switch instead of any direct connect triggering . . please solve
If you want to use this circuit to control a mechanical switch, then a relay is called for.
okk agree but what if i don't want to use any mechanical device ??
Too relay creates an electronic humm & also a very very short delay in switching comparitivly
Come to think of it, the output might not be strong enough to drive a relay.
In any event, you can feed the output to one of the following switching devices:
transistor
mosfet
scr
triac
solid-state relay
Etc.
