anum_pirkani
Junior Member level 3
Switching IC required instead of transistors
HELLO...!!!
I am designing a circuit with +5V, -5V and 50V input analog voltages. Along with this, i have two switch control signals.
When one of the switch control signals is high, the 2 output ports should have approximately 5V and 50V respectively and when the other switch control signal is high, the output voltages should be reverted as in 50V and 5V respectively.
i have designed this circuit but it is using 10 transistors (NPN AND PNP) occupying large space. I was looking for an IC or so that can compact my circuit, but i am not sure which IC can fulfill my purpose.
Any help would be appreciated.
Thanks a lot
Regards.
HELLO...!!!
Thanks a lot
Regards.
