brentf
Newbie
Newby here. Hope I have placed this in the right forum
The objective is to fill a holding or surge bin with grain with an auger or conveyor driven with a motor and electric clutch. Once the bin is full the auger will not run because the top sensor turns it off in bin and stay that way until a bottom sensor in bin is exposed and reactivates the auger. The bin would likely 3ft by 3ft by 3ft. placed over a cleaning mill.
This would be a 12 volt system. The relay coil would be a typical 150 to 200 ma draw to be used to turn the electric clutch on and off. The electric clutch will draw about 5 amps. Basically looking for a 3 way switch to turn the relay off and on to run the auger electric clutch. The sensor in the bin could be of any type. Of course the principal of this system is when the bottom sensor is exposed the relay will turn on the auger and run till the top sensor is covered to make it stop. Now the auger will stay turned off even when the product drops below the top sensor. It will stay that way until the product is again lower than the bottom sensor. Once it reaches that point auger turns back on. The cycle keeps repeating. I was hoping to modify or use a cheap kit or simple circuit to do this.
open to suggestion and direction.
brentf
brentf
