stube40
Member level 3
- Joined
- Feb 10, 2010
- Messages
- 55
- Helped
- 4
- Reputation
- 8
- Reaction score
- 4
- Trophy points
- 1,288
- Location
- Queensland, Australia
- Activity points
- 1,825
I'm trying to design an H-bridge that can control the output polarity of an electromagenetic coil with inductance of around 50mH and very low resistance. The source voltage is around 150V at 40A and hence the design and the switch selection aren't trivial.
The timing constraints make things even tougher - the circuit needs to be able to switch within a few ms of the control signal trigger going high. Once switched, the circuit will stay in the same polarity for at least 100ms, depending on the speed of the actuator at the time. Hence, it's far more about response time and lag than it is about actual switch frequency. Saying that, the target switch time is predictable with reasonable accuracy and hence it's possible to negate lag by advance switching (assuming the switch has consistent lag times).
I've considered both solid state relays (IGBTs and MOSFETs) as well as electro-mechanical relays. The solid state stuff seems to have considerable power losses due to the voltage drop between emitter and collector. The electro-mechanical relays suffer from being too slow and/or occasionaly bouncing when driven hard (which is likely to blow my PSU)
Does anyone have any suggestions for a good solid state solution that has low power losses, or an electromechanical solution that is fast enough and wont bounce?
