blackice504
Junior Member level 2
Hi all i am Designing a Invertor that uses High Freq's to drive a High Freq Transformer that will be converted back to DC then using a Pure sinewave Circuit to drive High voltage Mosfets to switch the DC voltage of 240volt the output would be a nice puresinewave 240volt 15amp
The DC volts in would be about 24volt DC from 2 car batts in series this will be regulated for the High Freq controler and the Pure Sinewave Controler.
The high Freq controler is based on the SG3524 wich will drive Transistors or mosfets that will then supply a 24volt Center Tap High Freq Transformer that will be bridge rectified back to 240VDC this will supply power for the High Voltage Fets that will switch 240volt @ 50hz the gate on the fets will be controlled by the Pure sinewave controller.
the invertor will a rating of 5000watts RMS.
any input will help Thanks.
I guess in a way this would be a Switch mode invertor.
