switch capacitor integrator
crazyfox
Junior Member level 2
hi :
I have a question about switched capacitor integrator.
The integrator was constructed from a folded cascode op-amp ,
which have common mode feedback.
If i give a "dc" input signal , what will i see at op-amp output?
the output voltage will accumulate form the common mode voltage?
or keep at common voltage?
Because i try to use this way to find the op-amp gain, is it correct?
(From the transfer function (z=1, DC), can get the finite gain of op-amp)
thanks
the output of integrator will step up if you apply a positive dc input. if you use fully-differential structure, the common-mode voltage of two outputs of opamp will be maintained on what you set by common-mode feedback.
this is a method to find the finite gain of opamp. in general, i simulate the gain of opamp in frequency domain by applying ac small signal to the input of opamp.
Thanks for your reply :
Do you mean if i use fully-differential structure,
the output of integrator will not step up if i apply a positive voltage?
But will set by common mode voltage, so i need to simulate it in frequency domain.
thanks
thanks
i mean the integrator will step up when applied a positive voltage for single-end and fully-differential both. when using fully-differential structure the common-mode voltage(not differential voltage) of integrator will be the setting in cmfb circuit.
as for the opamp gain, using ac small signal method to simulate the open-loop response of opamp.
    crazyfox
Because of INT, the output will become saturate.
