UStralian
I'm designing an amplifier board that takes in a low level single ended analog signal, goes through a balun, then to a differential amplifier then out to an ADC. The differential amplifier is an ADL5205 dual-channel amp which has its channels mirrored - ie the pin order on the input and output side is N-P-P-N. This order means the orientation of my baluns is problematic, and the routing to the ADC connector is also twisted. I can get the signals there without crossing layers (just), but I can't length match them without huge accordions. Is there any reason I can't just swap the N and P signals on both sides of the differential amplifier? They're AC coupled on both sides.
