Suspecting a pss/pnoise issue in a VCO
iVenky
Advanced Member level 2
College Station, Texas
Hi all,
I have designed a wide-range LC VCO, and I am running PSS/Pnoise for checking the phase noise of the VCO. I got suspicious about the results when I found that the phase noise started changing with tstab for a range of oscillation frequencies (For example, a tstab of 500n is giving me a phase noise of -101.8 dBc/Hz @ 1MHz while a tstab of 5u is giving me a phase noise of -108 dBc/Hz @1MHz!) Could you please help me out in figuring out whether the Pss/Pnoise results are proper or not? Is that something to do with the tolerance limit (it's the default value by the way)? How can I confirm if the results of pss/pnoise are correct? This is holding up my project, as I am not able to meet the required phase noise specs. I am also looking for resources to understand pss/pnoise functioning.
Also I had one more question. Is it possible to get different frequencies (an error of 3% to 4%) in transient simulation and pss?
Thanks!
Show me analysis statement of PSS and Pnoise.
And show me Simulation log file.
It could be, unless transient analysis results can reach steady state enoughly or if your VCO is QVCO.
Do you surely read my append ?
https://www.edaboard.com/threads/353039/#3
https://www.edaboard.com/threads/346180/#6
I have attached the spectre.out file.
I intentionally ran it for a tstab of 100 us.
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.2.0.510.isr18 32bit -- 7 Mar 2011
Copyright (C) 1989-2010 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
        5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
        6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
        6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
        6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
        7,085,700; 7,143,021; 7,493,240; 7,571,401.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: venkatraman.nataraj   Host: hera.ece.tamu.edu   HostID: 7F0100   PID: 25052
Memory  available: 215.1693 GB  physical: 270.4875 GB
CPU Type: AMD Opteron(tm) Processor 6174
          Processor PhysicalID CoreID Frequency
              0         0        0     2200.0
              1         3        0     2200.0
              2         2        0     2200.0
              3         1        0     2200.0
              4         0        1     2200.0
              5         3        1     2200.0
              6         2        1     2200.0
              7         1        1     2200.0
              8         0        2     2200.0
              9         3        2     2200.0
             10         2        2     2200.0
             11         1        2     2200.0
             12         0        3     2200.0
             13         3        3     2200.0
             14         2        3     2200.0
             15         1        3     2200.0
             16         0        4     2200.0
             17         3        4     2200.0
             18         2        4     2200.0
             19         1        4     2200.0
             20         0        5     2200.0
             21         3        5     2200.0
             22         2        5     2200.0
             23         1        5     2200.0
             24         0        0     2200.0
             25         3        0     2200.0
             26         2        0     2200.0
             27         1        0     2200.0
             28         0        1     2200.0
             29         3        1     2200.0
             30         2        1     2200.0
             31         1        1     2200.0
             32         0        2     2200.0
             33         3        2     2200.0
             34         2        2     2200.0
             35         1        2     2200.0
             36         0        3     2200.0
             37         3        3     2200.0
             38         2        3     2200.0
             39         1        3     2200.0
             40         0        4     2200.0
             41         3        4     2200.0
             42         2        4     2200.0
             43         1        4     2200.0
             44         0        5     2200.0
             45         3        5     2200.0
             46         2        5     2200.0
             47         1        5     2200.0
Simulating `input.scs' on hera.ece.tamu.edu at 2:50:46 AM, Fri Apr 15, 2016 (process id: 25052).
Command line:
        /softwares/Linux/cadence/mmsim72/tools.lnx86/spectre/bin/32bit/spectre  \
        input.scs +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre23_26667_218 -format sst2 -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 25052
Loading /softwares/Linux/cadence/mmsim72/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /softwares/Linux/cadence/mmsim72/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /softwares/Linux/cadence/mmsim72/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /softwares/Linux/cadence/mmsim72/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Time for NDB Parsing: CPU = 3.84941 s, elapsed = 4.09298 s.
Time accumulated: CPU = 3.84941 s, elapsed = 4.09298 s.
Peak resident memory used = 70.9 Mbytes.
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Opening directory input.ahdlSimDB/ (775)
Opening directory input.ahdlSimDB/bsource_1.input.ahdlcmi/ (775)
Opening directory input.ahdlSimDB/bsource_1.input.ahdlcmi/Linux2.6.18-408.el5+gcc/ (775)
Installed compiled interface for bsource_1.
Opening directory input.ahdlSimDB/bsource_2.input.ahdlcmi/ (775)
Opening directory input.ahdlSimDB/bsource_2.input.ahdlcmi/Linux2.6.18-408.el5+gcc/ (775)
Installed compiled interface for bsource_2.
Time for Elaboration: CPU = 176.973 ms, elapsed = 205.951 ms.
Time accumulated: CPU = 4.02639 s, elapsed = 4.29917 s.
Peak resident memory used = 80.4 Mbytes.
Time for EDB Visiting: CPU = 2.999 ms, elapsed = 2.94185 ms.
Time accumulated: CPU = 4.02939 s, elapsed = 4.30231 s.
Peak resident memory used = 80.8 Mbytes.
Notice from spectre during topology check.
    Only one connection to node `code5'.
Circuit inventory:
              nodes 26
              bsim4 20
          bsource_1 2
          bsource_2 2
          capacitor 12
           inductor 2
            isource 1
           resistor 2
            vsource 9
Time for parsing: CPU = 4 ms, elapsed = 5.19204 ms.
Time accumulated: CPU = 4.03339 s, elapsed = 4.30766 s.
Peak resident memory used = 81.4 Mbytes.
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre23_26667_218, ).
Periodic Steady-State Analysis `pss': guessed fund = 4.5 GHz
Notice from spectre during IC analysis, during periodic steady state analysis `pss'.
    There are 4 IC nodes defined.
    Initial condition computed for node voutp is in error by 115.624 mV (5.78121 %).
    Initial condition computed for node voutm is in error by 115.624 mV (5.78121 %).
    Initial condition computed for node net9 is in error by 115.624 mV (5.78121 %).
    Initial condition computed for node net8 is in error by 115.624 mV (5.78121 %).
        Decrease `rforce' to reduce error in computed initial conditions.  However, setting rforce too small may result in convergence difficulties or in the matrix becoming singular.
`pss': time = (0 s -> 100.001 us)
Important parameter values in tstab integration:
    start = 0 s
    outputstart = 0 s
    stop = 100.001 us
    period = 222.222 ps
    step = 100 ns
    maxstep = 8.88889 ps
    ic = all
    skipdc = no
    reltol = 1e-03
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    method = traponly
    lteratio = 3.5
    relref = sigglobal
    cmin = 0 F
    gmin = 1 pS
Warning from spectre at time = 2.8787 ps during periodic steady state analysis `pss'.
    WARNING (CMI-2682): I3.M9: The bulk-source junction forward bias voltage (952.407 mV) exceeds `VjsmFwd' = 932.717 mV.  The results are now incorrect because the junction current model has been linearized
    WARNING (CMI-2682): I3.M9: The bulk-drain junction forward bias voltage (954.169 mV) exceeds `VjdmFwd' = 934.988 mV.  The results are now incorrect because the junction current model has been linearized
    WARNING (CMI-2682): I3.M1: The bulk-source junction forward bias voltage (952.407 mV) exceeds `VjsmFwd' = 932.717 mV.  The results are now incorrect because the junction current model has been linearized
    WARNING (CMI-2682): I3.M1: The bulk-drain junction forward bias voltage (954.169 mV) exceeds `VjdmFwd' = 934.988 mV.  The results are now incorrect because the junction current model has been linearized
    WARNING (CMI-2682): I3.M4: The bulk-source junction forward bias voltage (952.407 mV) exceeds `VjsmFwd' = 932.717 mV.  The results are now incorrect because the junction current model has been linearized
        Further occurrences of this warning will be suppressed.
Notice from spectre at time = 33.839 ps during periodic steady state analysis `pss'.
    I3.M9: The bulk-source junction returns to normal bias condition
    I3.M9: The bulk-drain junction returns to normal bias condition
    I3.M1: The bulk-source junction returns to normal bias condition
    I3.M1: The bulk-drain junction returns to normal bias condition
    I3.M4: The bulk-source junction returns to normal bias condition
        Further occurrences of this notice will be suppressed.
    pss: time = 93.74 ns   (93.7 m%), step = 3.603 ps     (3.6 u%)
    pss: time = 189.4 ns    (189 m%), step = 8.889 ps    (8.89 u%)
    pss: time = 284.4 ns    (284 m%), step = 5.262 ps    (5.26 u%)
    pss: time = 379.2 ns    (379 m%), step = 5.914 ps    (5.91 u%)
    pss: time = 472.3 ns    (472 m%), step = 4.033 ps    (4.03 u%)
    pss: time = 566.2 ns    (566 m%), step = 3.25 ps     (3.25 u%)
    pss: time = 660.9 ns    (661 m%), step = 2.822 ps    (2.82 u%)
    pss: time = 756.7 ns    (757 m%), step = 2.598 ps     (2.6 u%)
    pss: time = 851.6 ns    (852 m%), step = 3.028 ps    (3.03 u%)
    pss: time = 945.7 ns    (946 m%), step = 3.618 ps    (3.62 u%)
    pss: time = 1.04 us     (1.04 %), step = 2.352 ps    (2.35 u%)
    pss: time = 1.133 us    (1.13 %), step = 3.183 ps    (3.18 u%)
    pss: time = 1.229 us    (1.23 %), step = 3.616 ps    (3.62 u%)
    pss: time = 1.321 us    (1.32 %), step = 3.12 ps     (3.12 u%)
    pss: time = 1.411 us    (1.41 %), step = 2.635 ps    (2.64 u%)
    pss: time = 1.504 us     (1.5 %), step = 4.742 ps    (4.74 u%)
    pss: time = 1.598 us     (1.6 %), step = 2.719 ps    (2.72 u%)
    pss: time = 1.69 us     (1.69 %), step = 8.889 ps    (8.89 u%)
    pss: time = 1.783 us    (1.78 %), step = 6.904 ps     (6.9 u%)
    pss: time = 1.874 us    (1.87 %), step = 5.129 ps    (5.13 u%)
    pss: time = 1.966 us    (1.97 %), step = 2.678 ps    (2.68 u%)
    pss: time = 2.058 us    (2.06 %), step = 4.931 ps    (4.93 u%)
    pss: time = 2.148 us    (2.15 %), step = 7.662 ps    (7.66 u%)
    pss: time = 2.242 us    (2.24 %), step = 3.291 ps    (3.29 u%)
    pss: time = 2.335 us    (2.34 %), step = 8.889 ps    (8.89 u%)
    pss: time = 2.428 us    (2.43 %), step = 8.889 ps    (8.89 u%)
    pss: time = 2.5 us       (2.5 %), step = 8.165 ps    (8.16 u%)
    pss: time = 2.594 us    (2.59 %), step = 3.012 ps    (3.01 u%)
    pss: time = 2.686 us    (2.69 %), step = 4.446 ps    (4.45 u%)
    pss: time = 2.778 us    (2.78 %), step = 2.567 ps    (2.57 u%)
    pss: time = 2.87 us     (2.87 %), step = 5.002 ps       (5 u%)
    pss: time = 2.963 us    (2.96 %), step = 6.664 ps    (6.66 u%)
    pss: time = 3.056 us    (3.06 %), step = 4.928 ps    (4.93 u%)
    pss: time = 3.15 us     (3.15 %), step = 4.095 ps    (4.09 u%)
    pss: time = 3.242 us    (3.24 %), step = 8.889 ps    (8.89 u%)
    pss: time = 3.334 us    (3.33 %), step = 6.699 ps     (6.7 u%)
    pss: time = 3.425 us    (3.42 %), step = 3.94 ps     (3.94 u%)
    pss: time = 3.517 us    (3.52 %), step = 2.544 ps    (2.54 u%)
    pss: time = 3.61 us     (3.61 %), step = 4.532 ps    (4.53 u%)
    pss: time = 3.7 us       (3.7 %), step = 4.797 ps     (4.8 u%)
    pss: time = 3.791 us    (3.79 %), step = 5.299 ps     (5.3 u%)
    pss: time = 3.883 us    (3.88 %), step = 2.694 ps    (2.69 u%)
    pss: time = 3.974 us    (3.97 %), step = 2.949 ps    (2.95 u%)
    pss: time = 4.064 us    (4.06 %), step = 3.626 ps    (3.63 u%)
    pss: time = 4.155 us    (4.15 %), step = 3.053 ps    (3.05 u%)
    pss: time = 4.247 us    (4.25 %), step = 2.804 ps     (2.8 u%)
    pss: time = 4.341 us    (4.34 %), step = 4.867 ps    (4.87 u%)
    pss: time = 4.432 us    (4.43 %), step = 4.59 ps     (4.59 u%)
    pss: time = 4.523 us    (4.52 %), step = 8.889 ps    (8.89 u%)
    pss: time = 4.614 us    (4.61 %), step = 8.889 ps    (8.89 u%)
    pss: time = 4.706 us    (4.71 %), step = 2.644 ps    (2.64 u%)
    pss: time = 4.797 us     (4.8 %), step = 3.637 ps    (3.64 u%)
    pss: time = 4.888 us    (4.89 %), step = 5.22 ps     (5.22 u%)
    pss: time = 4.979 us    (4.98 %), step = 5.927 ps    (5.93 u%)
    pss: time = 5.071 us    (5.07 %), step = 5.824 ps    (5.82 u%)
    pss: time = 5.165 us    (5.16 %), step = 2.854 ps    (2.85 u%)
    pss: time = 5.261 us    (5.26 %), step = 8.889 ps    (8.89 u%)
    pss: time = 5.356 us    (5.36 %), step = 5.917 ps    (5.92 u%)
    pss: time = 5.451 us    (5.45 %), step = 1.093 ps    (1.09 u%)
    pss: time = 5.543 us    (5.54 %), step = 2.439 ps    (2.44 u%)
    pss: time = 5.634 us    (5.63 %), step = 8.351 ps    (8.35 u%)
    pss: time = 5.724 us    (5.72 %), step = 944.5 fs     (944 n%)
    pss: time = 5.814 us    (5.81 %), step = 4.663 ps    (4.66 u%)
    pss: time = 5.904 us     (5.9 %), step = 3.529 ps    (3.53 u%)
    pss: time = 5.996 us       (6 %), step = 4.807 ps    (4.81 u%)
    pss: time = 6.085 us    (6.09 %), step = 4.242 ps    (4.24 u%)
    pss: time = 6.178 us    (6.18 %), step = 4.559 ps    (4.56 u%)
    pss: time = 6.268 us    (6.27 %), step = 7.249 ps    (7.25 u%)
    pss: time = 6.359 us    (6.36 %), step = 2.97 ps     (2.97 u%)
    pss: time = 6.447 us    (6.45 %), step = 3.708 ps    (3.71 u%)
    pss: time = 6.534 us    (6.53 %), step = 2.546 ps    (2.55 u%)
    pss: time = 6.621 us    (6.62 %), step = 2.872 ps    (2.87 u%)
    pss: time = 6.707 us    (6.71 %), step = 4.975 ps    (4.98 u%)
    pss: time = 6.794 us    (6.79 %), step = 5.069 ps    (5.07 u%)
    pss: time = 6.88 us     (6.88 %), step = 2.75 ps     (2.75 u%)
    pss: time = 6.967 us    (6.97 %), step = 3.242 ps    (3.24 u%)
    pss: time = 7.054 us    (7.05 %), step = 1.086 ps    (1.09 u%)
    pss: time = 7.141 us    (7.14 %), step = 3.627 ps    (3.63 u%)
    pss: time = 7.228 us    (7.23 %), step = 8 ps           (8 u%)
    pss: time = 7.315 us    (7.32 %), step = 5.028 ps    (5.03 u%)
    pss: time = 7.404 us     (7.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 7.492 us    (7.49 %), step = 6.079 ps    (6.08 u%)
    pss: time = 7.5 us       (7.5 %), step = 5.042 ps    (5.04 u%)
    pss: time = 7.589 us    (7.59 %), step = 2.418 ps    (2.42 u%)
    pss: time = 7.679 us    (7.68 %), step = 8.271 ps    (8.27 u%)
    pss: time = 7.769 us    (7.77 %), step = 2.696 ps     (2.7 u%)
    pss: time = 7.857 us    (7.86 %), step = 7.379 ps    (7.38 u%)
    pss: time = 7.946 us    (7.95 %), step = 5.101 ps     (5.1 u%)
    pss: time = 8.035 us    (8.03 %), step = 1.051 ps    (1.05 u%)
    pss: time = 8.123 us    (8.12 %), step = 4.579 ps    (4.58 u%)
    pss: time = 8.213 us    (8.21 %), step = 4.655 ps    (4.65 u%)
    pss: time = 8.303 us     (8.3 %), step = 2.507 ps    (2.51 u%)
    pss: time = 8.39 us     (8.39 %), step = 4.832 ps    (4.83 u%)
    pss: time = 8.48 us     (8.48 %), step = 6.804 ps     (6.8 u%)
    pss: time = 8.569 us    (8.57 %), step = 4.321 ps    (4.32 u%)
    pss: time = 8.659 us    (8.66 %), step = 4.656 ps    (4.66 u%)
    pss: time = 8.749 us    (8.75 %), step = 7.345 ps    (7.34 u%)
    pss: time = 8.839 us    (8.84 %), step = 7.599 ps     (7.6 u%)
    pss: time = 8.928 us    (8.93 %), step = 3.048 ps    (3.05 u%)
    pss: time = 9.018 us    (9.02 %), step = 2.202 ps     (2.2 u%)
    pss: time = 9.107 us    (9.11 %), step = 4.861 ps    (4.86 u%)
    pss: time = 9.197 us     (9.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 9.287 us    (9.29 %), step = 4.581 ps    (4.58 u%)
    pss: time = 9.378 us    (9.38 %), step = 7.184 ps    (7.18 u%)
    pss: time = 9.467 us    (9.47 %), step = 4.819 ps    (4.82 u%)
    pss: time = 9.558 us    (9.56 %), step = 4.586 ps    (4.59 u%)
    pss: time = 9.649 us    (9.65 %), step = 6.747 ps    (6.75 u%)
    pss: time = 9.739 us    (9.74 %), step = 981.5 fs     (981 n%)
    pss: time = 9.83 us     (9.83 %), step = 8.889 ps    (8.89 u%)
    pss: time = 9.921 us    (9.92 %), step = 8.889 ps    (8.89 u%)
    pss: time = 10.01 us      (10 %), step = 4.437 ps    (4.44 u%)
    pss: time = 10.1 us     (10.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 10.19 us    (10.2 %), step = 3.413 ps    (3.41 u%)
    pss: time = 10.28 us    (10.3 %), step = 3.801 ps     (3.8 u%)
    pss: time = 10.37 us    (10.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 10.46 us    (10.5 %), step = 4.178 ps    (4.18 u%)
    pss: time = 10.55 us    (10.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 10.64 us    (10.6 %), step = 2.844 ps    (2.84 u%)
    pss: time = 10.73 us    (10.7 %), step = 2.722 ps    (2.72 u%)
    pss: time = 10.82 us    (10.8 %), step = 4.494 ps    (4.49 u%)
    pss: time = 10.91 us    (10.9 %), step = 2.177 ps    (2.18 u%)
    pss: time = 11 us         (11 %), step = 8.889 ps    (8.89 u%)
    pss: time = 11.09 us    (11.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 11.18 us    (11.2 %), step = 1.935 ps    (1.93 u%)
    pss: time = 11.27 us    (11.3 %), step = 3.104 ps     (3.1 u%)
    pss: time = 11.36 us    (11.4 %), step = 8.105 ps    (8.11 u%)
    pss: time = 11.45 us    (11.4 %), step = 4.359 ps    (4.36 u%)
    pss: time = 11.53 us    (11.5 %), step = 2.967 ps    (2.97 u%)
    pss: time = 11.62 us    (11.6 %), step = 2.727 ps    (2.73 u%)
    pss: time = 11.71 us    (11.7 %), step = 2.998 ps       (3 u%)
    pss: time = 11.8 us     (11.8 %), step = 4.427 ps    (4.43 u%)
    pss: time = 11.89 us    (11.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 11.98 us      (12 %), step = 4.888 ps    (4.89 u%)
    pss: time = 12.07 us    (12.1 %), step = 4.9 ps       (4.9 u%)
    pss: time = 12.15 us    (12.2 %), step = 5.894 ps    (5.89 u%)
    pss: time = 12.24 us    (12.2 %), step = 3.846 ps    (3.85 u%)
    pss: time = 12.33 us    (12.3 %), step = 7.92 ps     (7.92 u%)
    pss: time = 12.42 us    (12.4 %), step = 2.961 ps    (2.96 u%)
    pss: time = 12.5 us     (12.5 %), step = 4.572 ps    (4.57 u%)
    pss: time = 12.59 us    (12.6 %), step = 3.514 ps    (3.51 u%)
    pss: time = 12.68 us    (12.7 %), step = 4.839 ps    (4.84 u%)
    pss: time = 12.76 us    (12.8 %), step = 3.868 ps    (3.87 u%)
    pss: time = 12.85 us    (12.9 %), step = 3.401 ps     (3.4 u%)
    pss: time = 12.94 us    (12.9 %), step = 4.981 ps    (4.98 u%)
    pss: time = 13.03 us      (13 %), step = 4.582 ps    (4.58 u%)
    pss: time = 13.12 us    (13.1 %), step = 4.155 ps    (4.15 u%)
    pss: time = 13.21 us    (13.2 %), step = 3.25 ps     (3.25 u%)
    pss: time = 13.29 us    (13.3 %), step = 1.074 ps    (1.07 u%)
    pss: time = 13.38 us    (13.4 %), step = 1.886 ps    (1.89 u%)
    pss: time = 13.47 us    (13.5 %), step = 1.054 ps    (1.05 u%)
    pss: time = 13.56 us    (13.6 %), step = 5.158 ps    (5.16 u%)
    pss: time = 13.65 us    (13.6 %), step = 4.075 ps    (4.08 u%)
    pss: time = 13.73 us    (13.7 %), step = 3.831 ps    (3.83 u%)
    pss: time = 13.82 us    (13.8 %), step = 4.856 ps    (4.86 u%)
    pss: time = 13.91 us    (13.9 %), step = 3.501 ps     (3.5 u%)
    pss: time = 14 us         (14 %), step = 2.203 ps     (2.2 u%)
    pss: time = 14.09 us    (14.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 14.18 us    (14.2 %), step = 3.11 ps     (3.11 u%)
    pss: time = 14.26 us    (14.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 14.35 us    (14.4 %), step = 2.788 ps    (2.79 u%)
    pss: time = 14.44 us    (14.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 14.53 us    (14.5 %), step = 5.565 ps    (5.57 u%)
    pss: time = 14.62 us    (14.6 %), step = 2.991 ps    (2.99 u%)
    pss: time = 14.7 us     (14.7 %), step = 4.126 ps    (4.13 u%)
    pss: time = 14.79 us    (14.8 %), step = 4.358 ps    (4.36 u%)
    pss: time = 14.88 us    (14.9 %), step = 4.412 ps    (4.41 u%)
    pss: time = 14.97 us      (15 %), step = 2.227 ps    (2.23 u%)
    pss: time = 15.06 us    (15.1 %), step = 5.16 ps     (5.16 u%)
    pss: time = 15.15 us    (15.1 %), step = 1.064 ps    (1.06 u%)
    pss: time = 15.24 us    (15.2 %), step = 4.119 ps    (4.12 u%)
    pss: time = 15.33 us    (15.3 %), step = 5.271 ps    (5.27 u%)
    pss: time = 15.41 us    (15.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 15.5 us     (15.5 %), step = 2.367 ps    (2.37 u%)
    pss: time = 15.59 us    (15.6 %), step = 4.435 ps    (4.44 u%)
    pss: time = 15.68 us    (15.7 %), step = 4.331 ps    (4.33 u%)
    pss: time = 15.76 us    (15.8 %), step = 3.17 ps     (3.17 u%)
    pss: time = 15.85 us    (15.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 15.94 us    (15.9 %), step = 6.74 ps     (6.74 u%)
    pss: time = 16.03 us      (16 %), step = 4.761 ps    (4.76 u%)
    pss: time = 16.12 us    (16.1 %), step = 3.389 ps    (3.39 u%)
    pss: time = 16.2 us     (16.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 16.29 us    (16.3 %), step = 3.255 ps    (3.26 u%)
    pss: time = 16.38 us    (16.4 %), step = 4.531 ps    (4.53 u%)
    pss: time = 16.47 us    (16.5 %), step = 5.468 ps    (5.47 u%)
    pss: time = 16.55 us    (16.6 %), step = 2.994 ps    (2.99 u%)
    pss: time = 16.64 us    (16.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 16.73 us    (16.7 %), step = 8.105 ps     (8.1 u%)
    pss: time = 16.82 us    (16.8 %), step = 3.779 ps    (3.78 u%)
    pss: time = 16.91 us    (16.9 %), step = 4.36 ps     (4.36 u%)
    pss: time = 16.99 us      (17 %), step = 2.064 ps    (2.06 u%)
    pss: time = 17.08 us    (17.1 %), step = 3.584 ps    (3.58 u%)
    pss: time = 17.17 us    (17.2 %), step = 4.588 ps    (4.59 u%)
    pss: time = 17.26 us    (17.3 %), step = 5.505 ps     (5.5 u%)
    pss: time = 17.34 us    (17.3 %), step = 2.929 ps    (2.93 u%)
    pss: time = 17.43 us    (17.4 %), step = 3.187 ps    (3.19 u%)
    pss: time = 17.5 us     (17.5 %), step = 5.034 ps    (5.03 u%)
    pss: time = 17.59 us    (17.6 %), step = 1.119 ps    (1.12 u%)
    pss: time = 17.68 us    (17.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 17.76 us    (17.8 %), step = 2.305 ps    (2.31 u%)
    pss: time = 17.85 us    (17.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 17.94 us    (17.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 18.02 us      (18 %), step = 3.847 ps    (3.85 u%)
    pss: time = 18.11 us    (18.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 18.2 us     (18.2 %), step = 3.748 ps    (3.75 u%)
    pss: time = 18.29 us    (18.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 18.38 us    (18.4 %), step = 4.403 ps     (4.4 u%)
    pss: time = 18.46 us    (18.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 18.55 us    (18.5 %), step = 2.786 ps    (2.79 u%)
    pss: time = 18.64 us    (18.6 %), step = 3.219 ps    (3.22 u%)
    pss: time = 18.73 us    (18.7 %), step = 3.714 ps    (3.71 u%)
    pss: time = 18.81 us    (18.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 18.9 us     (18.9 %), step = 4.408 ps    (4.41 u%)
    pss: time = 18.99 us      (19 %), step = 4.886 ps    (4.89 u%)
    pss: time = 19.08 us    (19.1 %), step = 3.134 ps    (3.13 u%)
    pss: time = 19.17 us    (19.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 19.25 us    (19.3 %), step = 1.848 ps    (1.85 u%)
    pss: time = 19.34 us    (19.3 %), step = 5.25 ps     (5.25 u%)
    pss: time = 19.43 us    (19.4 %), step = 4.25 ps     (4.25 u%)
    pss: time = 19.51 us    (19.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 19.6 us     (19.6 %), step = 4.069 ps    (4.07 u%)
    pss: time = 19.69 us    (19.7 %), step = 4.407 ps    (4.41 u%)
    pss: time = 19.78 us    (19.8 %), step = 5.622 ps    (5.62 u%)
    pss: time = 19.86 us    (19.9 %), step = 2.992 ps    (2.99 u%)
    pss: time = 19.95 us      (20 %), step = 4.831 ps    (4.83 u%)
    pss: time = 20.04 us      (20 %), step = 2.998 ps       (3 u%)
    pss: time = 20.13 us    (20.1 %), step = 4.761 ps    (4.76 u%)
    pss: time = 20.21 us    (20.2 %), step = 3.576 ps    (3.58 u%)
    pss: time = 20.3 us     (20.3 %), step = 4.898 ps     (4.9 u%)
    pss: time = 20.39 us    (20.4 %), step = 3.881 ps    (3.88 u%)
    pss: time = 20.48 us    (20.5 %), step = 3 ps           (3 u%)
    pss: time = 20.56 us    (20.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 20.65 us    (20.7 %), step = 2.744 ps    (2.74 u%)
    pss: time = 20.74 us    (20.7 %), step = 3.159 ps    (3.16 u%)
    pss: time = 20.83 us    (20.8 %), step = 3.081 ps    (3.08 u%)
    pss: time = 20.92 us    (20.9 %), step = 5.077 ps    (5.08 u%)
    pss: time = 21 us         (21 %), step = 3.674 ps    (3.67 u%)
    pss: time = 21.09 us    (21.1 %), step = 5.014 ps    (5.01 u%)
    pss: time = 21.18 us    (21.2 %), step = 2.993 ps    (2.99 u%)
    pss: time = 21.27 us    (21.3 %), step = 5.184 ps    (5.18 u%)
    pss: time = 21.36 us    (21.4 %), step = 3.93 ps     (3.93 u%)
    pss: time = 21.44 us    (21.4 %), step = 4.424 ps    (4.42 u%)
    pss: time = 21.53 us    (21.5 %), step = 6.533 ps    (6.53 u%)
    pss: time = 21.62 us    (21.6 %), step = 2.987 ps    (2.99 u%)
    pss: time = 21.71 us    (21.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 21.79 us    (21.8 %), step = 2.229 ps    (2.23 u%)
    pss: time = 21.88 us    (21.9 %), step = 1.085 ps    (1.08 u%)
    pss: time = 21.97 us      (22 %), step = 3.579 ps    (3.58 u%)
    pss: time = 22.05 us    (22.1 %), step = 3.357 ps    (3.36 u%)
    pss: time = 22.14 us    (22.1 %), step = 3.626 ps    (3.63 u%)
    pss: time = 22.23 us    (22.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 22.32 us    (22.3 %), step = 1.1 ps       (1.1 u%)
    pss: time = 22.4 us     (22.4 %), step = 4.715 ps    (4.72 u%)
    pss: time = 22.49 us    (22.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 22.5 us     (22.5 %), step = 6.413 ps    (6.41 u%)
    pss: time = 22.59 us    (22.6 %), step = 8.245 ps    (8.25 u%)
    pss: time = 22.67 us    (22.7 %), step = 4.648 ps    (4.65 u%)
    pss: time = 22.76 us    (22.8 %), step = 4.428 ps    (4.43 u%)
    pss: time = 22.85 us    (22.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 22.94 us    (22.9 %), step = 1.964 ps    (1.96 u%)
    pss: time = 23.03 us      (23 %), step = 4.291 ps    (4.29 u%)
    pss: time = 23.11 us    (23.1 %), step = 3.863 ps    (3.86 u%)
    pss: time = 23.2 us     (23.2 %), step = 1.004 ps       (1 u%)
    pss: time = 23.29 us    (23.3 %), step = 2.143 ps    (2.14 u%)
    pss: time = 23.38 us    (23.4 %), step = 5.782 ps    (5.78 u%)
    pss: time = 23.46 us    (23.5 %), step = 4.122 ps    (4.12 u%)
    pss: time = 23.55 us    (23.6 %), step = 2.98 ps     (2.98 u%)
    pss: time = 23.64 us    (23.6 %), step = 6.672 ps    (6.67 u%)
    pss: time = 23.72 us    (23.7 %), step = 5.197 ps     (5.2 u%)
    pss: time = 23.81 us    (23.8 %), step = 1.009 ps    (1.01 u%)
    pss: time = 23.9 us     (23.9 %), step = 4.686 ps    (4.69 u%)
    pss: time = 23.99 us      (24 %), step = 3.537 ps    (3.54 u%)
    pss: time = 24.07 us    (24.1 %), step = 4.888 ps    (4.89 u%)
    pss: time = 24.16 us    (24.2 %), step = 3.246 ps    (3.25 u%)
    pss: time = 24.25 us    (24.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 24.33 us    (24.3 %), step = 4.547 ps    (4.55 u%)
    pss: time = 24.42 us    (24.4 %), step = 2.713 ps    (2.71 u%)
    pss: time = 24.51 us    (24.5 %), step = 1.911 ps    (1.91 u%)
    pss: time = 24.59 us    (24.6 %), step = 4.719 ps    (4.72 u%)
    pss: time = 24.68 us    (24.7 %), step = 2.763 ps    (2.76 u%)
    pss: time = 24.77 us    (24.8 %), step = 5.14 ps     (5.14 u%)
    pss: time = 24.85 us    (24.9 %), step = 3.562 ps    (3.56 u%)
    pss: time = 24.94 us    (24.9 %), step = 5.127 ps    (5.13 u%)
    pss: time = 25.03 us      (25 %), step = 3.263 ps    (3.26 u%)
    pss: time = 25.11 us    (25.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 25.2 us     (25.2 %), step = 4.823 ps    (4.82 u%)
    pss: time = 25.29 us    (25.3 %), step = 2.838 ps    (2.84 u%)
    pss: time = 25.38 us    (25.4 %), step = 3.588 ps    (3.59 u%)
    pss: time = 25.46 us    (25.5 %), step = 1.45 ps     (1.45 u%)
    pss: time = 25.55 us    (25.6 %), step = 5.04 ps     (5.04 u%)
    pss: time = 25.64 us    (25.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 25.73 us    (25.7 %), step = 2.226 ps    (2.23 u%)
    pss: time = 25.81 us    (25.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 25.9 us     (25.9 %), step = 4.637 ps    (4.64 u%)
    pss: time = 25.99 us      (26 %), step = 8.889 ps    (8.89 u%)
    pss: time = 26.08 us    (26.1 %), step = 954.4 fs     (954 n%)
    pss: time = 26.16 us    (26.2 %), step = 5.492 ps    (5.49 u%)
    pss: time = 26.25 us    (26.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 26.34 us    (26.3 %), step = 4.888 ps    (4.89 u%)
    pss: time = 26.43 us    (26.4 %), step = 2.199 ps     (2.2 u%)
    pss: time = 26.52 us    (26.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 26.6 us     (26.6 %), step = 3.612 ps    (3.61 u%)
    pss: time = 26.69 us    (26.7 %), step = 6.518 ps    (6.52 u%)
    pss: time = 26.78 us    (26.8 %), step = 1.689 ps    (1.69 u%)
    pss: time = 26.87 us    (26.9 %), step = 4.326 ps    (4.33 u%)
    pss: time = 26.95 us      (27 %), step = 3.076 ps    (3.08 u%)
    pss: time = 27.04 us      (27 %), step = 5.048 ps    (5.05 u%)
    pss: time = 27.13 us    (27.1 %), step = 3.59 ps     (3.59 u%)
    pss: time = 27.22 us    (27.2 %), step = 3.613 ps    (3.61 u%)
    pss: time = 27.3 us     (27.3 %), step = 1.99 ps     (1.99 u%)
    pss: time = 27.39 us    (27.4 %), step = 5.273 ps    (5.27 u%)
    pss: time = 27.48 us    (27.5 %), step = 3.38 ps     (3.38 u%)
    pss: time = 27.5 us     (27.5 %), step = 4.189 ps    (4.19 u%)
    pss: time = 27.59 us    (27.6 %), step = 3.992 ps    (3.99 u%)
    pss: time = 27.67 us    (27.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 27.76 us    (27.8 %), step = 4.448 ps    (4.45 u%)
    pss: time = 27.85 us    (27.8 %), step = 3.79 ps     (3.79 u%)
    pss: time = 27.94 us    (27.9 %), step = 3.546 ps    (3.55 u%)
    pss: time = 28.03 us      (28 %), step = 2.392 ps    (2.39 u%)
    pss: time = 28.11 us    (28.1 %), step = 5.214 ps    (5.21 u%)
    pss: time = 28.2 us     (28.2 %), step = 7.896 ps     (7.9 u%)
    pss: time = 28.29 us    (28.3 %), step = 4.688 ps    (4.69 u%)
    pss: time = 28.38 us    (28.4 %), step = 3.537 ps    (3.54 u%)
    pss: time = 28.46 us    (28.5 %), step = 1.924 ps    (1.92 u%)
    pss: time = 28.55 us    (28.6 %), step = 4.783 ps    (4.78 u%)
    pss: time = 28.64 us    (28.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 28.73 us    (28.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 28.81 us    (28.8 %), step = 5.382 ps    (5.38 u%)
    pss: time = 28.9 us     (28.9 %), step = 3.621 ps    (3.62 u%)
    pss: time = 28.99 us      (29 %), step = 4.446 ps    (4.45 u%)
    pss: time = 29.08 us    (29.1 %), step = 3.652 ps    (3.65 u%)
    pss: time = 29.16 us    (29.2 %), step = 4.806 ps    (4.81 u%)
    pss: time = 29.25 us    (29.3 %), step = 3.603 ps     (3.6 u%)
    pss: time = 29.34 us    (29.3 %), step = 4.248 ps    (4.25 u%)
    pss: time = 29.43 us    (29.4 %), step = 4.727 ps    (4.73 u%)
    pss: time = 29.51 us    (29.5 %), step = 1.185 ps    (1.18 u%)
    pss: time = 29.6 us     (29.6 %), step = 1.979 ps    (1.98 u%)
    pss: time = 29.69 us    (29.7 %), step = 3.396 ps     (3.4 u%)
    pss: time = 29.78 us    (29.8 %), step = 5.803 ps     (5.8 u%)
    pss: time = 29.86 us    (29.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 29.95 us      (30 %), step = 3.076 ps    (3.08 u%)
    pss: time = 30.04 us      (30 %), step = 3.317 ps    (3.32 u%)
    pss: time = 30.12 us    (30.1 %), step = 6.478 ps    (6.48 u%)
    pss: time = 30.21 us    (30.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 30.3 us     (30.3 %), step = 7.723 ps    (7.72 u%)
    pss: time = 30.39 us    (30.4 %), step = 4.339 ps    (4.34 u%)
    pss: time = 30.48 us    (30.5 %), step = 3.114 ps    (3.11 u%)
    pss: time = 30.56 us    (30.6 %), step = 2.988 ps    (2.99 u%)
    pss: time = 30.65 us    (30.7 %), step = 2.221 ps    (2.22 u%)
    pss: time = 30.74 us    (30.7 %), step = 3.834 ps    (3.83 u%)
    pss: time = 30.83 us    (30.8 %), step = 4.758 ps    (4.76 u%)
    pss: time = 30.91 us    (30.9 %), step = 3.459 ps    (3.46 u%)
    pss: time = 31 us         (31 %), step = 8.889 ps    (8.89 u%)
    pss: time = 31.09 us    (31.1 %), step = 2.714 ps    (2.71 u%)
    pss: time = 31.18 us    (31.2 %), step = 4.044 ps    (4.04 u%)
    pss: time = 31.26 us    (31.3 %), step = 2.91 ps     (2.91 u%)
    pss: time = 31.35 us    (31.4 %), step = 4.116 ps    (4.12 u%)
    pss: time = 31.44 us    (31.4 %), step = 6.489 ps    (6.49 u%)
    pss: time = 31.53 us    (31.5 %), step = 4.822 ps    (4.82 u%)
    pss: time = 31.61 us    (31.6 %), step = 5.21 ps     (5.21 u%)
    pss: time = 31.7 us     (31.7 %), step = 4.184 ps    (4.18 u%)
    pss: time = 31.79 us    (31.8 %), step = 2.735 ps    (2.74 u%)
    pss: time = 31.88 us    (31.9 %), step = 4.402 ps     (4.4 u%)
    pss: time = 31.96 us      (32 %), step = 1.804 ps     (1.8 u%)
    pss: time = 32.05 us    (32.1 %), step = 986.5 fs     (987 n%)
    pss: time = 32.14 us    (32.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 32.23 us    (32.2 %), step = 3.203 ps     (3.2 u%)
    pss: time = 32.32 us    (32.3 %), step = 8.15 ps     (8.15 u%)
    pss: time = 32.4 us     (32.4 %), step = 3.489 ps    (3.49 u%)
    pss: time = 32.49 us    (32.5 %), step = 5.015 ps    (5.02 u%)
    pss: time = 32.5 us     (32.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 32.59 us    (32.6 %), step = 3.692 ps    (3.69 u%)
    pss: time = 32.68 us    (32.7 %), step = 2.639 ps    (2.64 u%)
    pss: time = 32.76 us    (32.8 %), step = 4.665 ps    (4.67 u%)
    pss: time = 32.85 us    (32.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 32.94 us    (32.9 %), step = 3.624 ps    (3.62 u%)
    pss: time = 33.03 us      (33 %), step = 4.154 ps    (4.15 u%)
    pss: time = 33.12 us    (33.1 %), step = 2.176 ps    (2.18 u%)
    pss: time = 33.2 us     (33.2 %), step = 3.773 ps    (3.77 u%)
    pss: time = 33.29 us    (33.3 %), step = 3.851 ps    (3.85 u%)
    pss: time = 33.38 us    (33.4 %), step = 4.713 ps    (4.71 u%)
    pss: time = 33.47 us    (33.5 %), step = 4.989 ps    (4.99 u%)
    pss: time = 33.55 us    (33.6 %), step = 1.853 ps    (1.85 u%)
    pss: time = 33.64 us    (33.6 %), step = 1.039 ps    (1.04 u%)
    pss: time = 33.73 us    (33.7 %), step = 3.657 ps    (3.66 u%)
    pss: time = 33.82 us    (33.8 %), step = 4.849 ps    (4.85 u%)
    pss: time = 33.91 us    (33.9 %), step = 5.114 ps    (5.11 u%)
    pss: time = 33.99 us      (34 %), step = 6.634 ps    (6.63 u%)
    pss: time = 34.08 us    (34.1 %), step = 3.258 ps    (3.26 u%)
    pss: time = 34.17 us    (34.2 %), step = 6.245 ps    (6.25 u%)
    pss: time = 34.26 us    (34.3 %), step = 5.504 ps     (5.5 u%)
    pss: time = 34.34 us    (34.3 %), step = 5.919 ps    (5.92 u%)
    pss: time = 34.43 us    (34.4 %), step = 835 fs       (835 n%)
    pss: time = 34.52 us    (34.5 %), step = 4.331 ps    (4.33 u%)
    pss: time = 34.61 us    (34.6 %), step = 5.679 ps    (5.68 u%)
    pss: time = 34.7 us     (34.7 %), step = 4.528 ps    (4.53 u%)
    pss: time = 34.78 us    (34.8 %), step = 4.757 ps    (4.76 u%)
    pss: time = 34.87 us    (34.9 %), step = 2.588 ps    (2.59 u%)
    pss: time = 34.96 us      (35 %), step = 5.058 ps    (5.06 u%)
    pss: time = 35.05 us      (35 %), step = 5.881 ps    (5.88 u%)
    pss: time = 35.13 us    (35.1 %), step = 4.307 ps    (4.31 u%)
    pss: time = 35.22 us    (35.2 %), step = 1.809 ps    (1.81 u%)
    pss: time = 35.31 us    (35.3 %), step = 4.644 ps    (4.64 u%)
    pss: time = 35.4 us     (35.4 %), step = 4.432 ps    (4.43 u%)
    pss: time = 35.49 us    (35.5 %), step = 3.625 ps    (3.63 u%)
    pss: time = 35.57 us    (35.6 %), step = 4.721 ps    (4.72 u%)
    pss: time = 35.66 us    (35.7 %), step = 5.021 ps    (5.02 u%)
    pss: time = 35.75 us    (35.7 %), step = 4.779 ps    (4.78 u%)
    pss: time = 35.84 us    (35.8 %), step = 5.315 ps    (5.31 u%)
    pss: time = 35.93 us    (35.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 36.01 us      (36 %), step = 3.303 ps     (3.3 u%)
    pss: time = 36.1 us     (36.1 %), step = 3.233 ps    (3.23 u%)
    pss: time = 36.19 us    (36.2 %), step = 2.633 ps    (2.63 u%)
    pss: time = 36.28 us    (36.3 %), step = 4.387 ps    (4.39 u%)
    pss: time = 36.36 us    (36.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 36.45 us    (36.5 %), step = 3.762 ps    (3.76 u%)
    pss: time = 36.54 us    (36.5 %), step = 3.844 ps    (3.84 u%)
    pss: time = 36.63 us    (36.6 %), step = 4.851 ps    (4.85 u%)
    pss: time = 36.72 us    (36.7 %), step = 4.605 ps     (4.6 u%)
    pss: time = 36.8 us     (36.8 %), step = 2.946 ps    (2.95 u%)
    pss: time = 36.89 us    (36.9 %), step = 1.13 ps     (1.13 u%)
    pss: time = 36.98 us      (37 %), step = 3.837 ps    (3.84 u%)
    pss: time = 37.07 us    (37.1 %), step = 3.706 ps    (3.71 u%)
    pss: time = 37.16 us    (37.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 37.24 us    (37.2 %), step = 4.692 ps    (4.69 u%)
    pss: time = 37.33 us    (37.3 %), step = 6.5 ps       (6.5 u%)
    pss: time = 37.42 us    (37.4 %), step = 4.695 ps    (4.69 u%)
    pss: time = 37.5 us     (37.5 %), step = 6.554 ps    (6.55 u%)
    pss: time = 37.59 us    (37.6 %), step = 4.656 ps    (4.66 u%)
    pss: time = 37.67 us    (37.7 %), step = 1.855 ps    (1.86 u%)
    pss: time = 37.76 us    (37.8 %), step = 4.301 ps     (4.3 u%)
    pss: time = 37.85 us    (37.8 %), step = 3.03 ps     (3.03 u%)
    pss: time = 37.94 us    (37.9 %), step = 4.35 ps     (4.35 u%)
    pss: time = 38.02 us      (38 %), step = 3.583 ps    (3.58 u%)
    pss: time = 38.11 us    (38.1 %), step = 4.896 ps     (4.9 u%)
    pss: time = 38.2 us     (38.2 %), step = 1.762 ps    (1.76 u%)
    pss: time = 38.28 us    (38.3 %), step = 2.892 ps    (2.89 u%)
    pss: time = 38.37 us    (38.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 38.46 us    (38.5 %), step = 4.777 ps    (4.78 u%)
    pss: time = 38.55 us    (38.5 %), step = 3.531 ps    (3.53 u%)
    pss: time = 38.63 us    (38.6 %), step = 5.618 ps    (5.62 u%)
    pss: time = 38.72 us    (38.7 %), step = 8.179 ps    (8.18 u%)
    pss: time = 38.81 us    (38.8 %), step = 4.867 ps    (4.87 u%)
    pss: time = 38.9 us     (38.9 %), step = 4.499 ps     (4.5 u%)
    pss: time = 38.99 us      (39 %), step = 5.137 ps    (5.14 u%)
    pss: time = 39.07 us    (39.1 %), step = 4.876 ps    (4.88 u%)
    pss: time = 39.16 us    (39.2 %), step = 4.764 ps    (4.76 u%)
    pss: time = 39.25 us    (39.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 39.34 us    (39.3 %), step = 2.891 ps    (2.89 u%)
    pss: time = 39.42 us    (39.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 39.51 us    (39.5 %), step = 4.852 ps    (4.85 u%)
    pss: time = 39.6 us     (39.6 %), step = 4.623 ps    (4.62 u%)
    pss: time = 39.69 us    (39.7 %), step = 4.454 ps    (4.45 u%)
    pss: time = 39.78 us    (39.8 %), step = 2.81 ps     (2.81 u%)
    pss: time = 39.86 us    (39.9 %), step = 5.009 ps    (5.01 u%)
    pss: time = 39.95 us      (40 %), step = 1.376 ps    (1.38 u%)
    pss: time = 40.04 us      (40 %), step = 8.485 ps    (8.49 u%)
    pss: time = 40.13 us    (40.1 %), step = 3.332 ps    (3.33 u%)
    pss: time = 40.21 us    (40.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 40.3 us     (40.3 %), step = 2.803 ps     (2.8 u%)
    pss: time = 40.39 us    (40.4 %), step = 3.156 ps    (3.16 u%)
    pss: time = 40.48 us    (40.5 %), step = 4.52 ps     (4.52 u%)
    pss: time = 40.56 us    (40.6 %), step = 5.027 ps    (5.03 u%)
    pss: time = 40.65 us    (40.7 %), step = 5.23 ps     (5.23 u%)
    pss: time = 40.74 us    (40.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 40.83 us    (40.8 %), step = 3.536 ps    (3.54 u%)
    pss: time = 40.92 us    (40.9 %), step = 5.305 ps     (5.3 u%)
    pss: time = 41 us         (41 %), step = 2.996 ps       (3 u%)
    pss: time = 41.09 us    (41.1 %), step = 4.351 ps    (4.35 u%)
    pss: time = 41.18 us    (41.2 %), step = 3.059 ps    (3.06 u%)
    pss: time = 41.27 us    (41.3 %), step = 5.287 ps    (5.29 u%)
    pss: time = 41.36 us    (41.4 %), step = 4.806 ps    (4.81 u%)
    pss: time = 41.44 us    (41.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 41.53 us    (41.5 %), step = 3.624 ps    (3.62 u%)
    pss: time = 41.62 us    (41.6 %), step = 4.439 ps    (4.44 u%)
    pss: time = 41.71 us    (41.7 %), step = 1.932 ps    (1.93 u%)
    pss: time = 41.79 us    (41.8 %), step = 3.569 ps    (3.57 u%)
    pss: time = 41.88 us    (41.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 41.97 us      (42 %), step = 3.297 ps     (3.3 u%)
    pss: time = 42.06 us    (42.1 %), step = 1.864 ps    (1.86 u%)
    pss: time = 42.15 us    (42.1 %), step = 2.996 ps       (3 u%)
    pss: time = 42.23 us    (42.2 %), step = 7.844 ps    (7.84 u%)
    pss: time = 42.32 us    (42.3 %), step = 4.816 ps    (4.82 u%)
    pss: time = 42.41 us    (42.4 %), step = 2.812 ps    (2.81 u%)
    pss: time = 42.5 us     (42.5 %), step = 4.713 ps    (4.71 u%)
    pss: time = 42.5 us     (42.5 %), step = 5.142 ps    (5.14 u%)
    pss: time = 42.59 us    (42.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 42.68 us    (42.7 %), step = 4.904 ps     (4.9 u%)
    pss: time = 42.76 us    (42.8 %), step = 1.781 ps    (1.78 u%)
    pss: time = 42.85 us    (42.9 %), step = 4.565 ps    (4.56 u%)
    pss: time = 42.94 us    (42.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 43.03 us      (43 %), step = 2.613 ps    (2.61 u%)
    pss: time = 43.11 us    (43.1 %), step = 4.518 ps    (4.52 u%)
    pss: time = 43.2 us     (43.2 %), step = 3.771 ps    (3.77 u%)
    pss: time = 43.29 us    (43.3 %), step = 3.422 ps    (3.42 u%)
    pss: time = 43.38 us    (43.4 %), step = 1.042 ps    (1.04 u%)
    pss: time = 43.46 us    (43.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 43.55 us    (43.6 %), step = 6.492 ps    (6.49 u%)
    pss: time = 43.64 us    (43.6 %), step = 8.078 ps    (8.08 u%)
    pss: time = 43.73 us    (43.7 %), step = 1.926 ps    (1.93 u%)
    pss: time = 43.81 us    (43.8 %), step = 4.866 ps    (4.87 u%)
    pss: time = 43.9 us     (43.9 %), step = 1.186 ps    (1.19 u%)
    pss: time = 43.99 us      (44 %), step = 4.682 ps    (4.68 u%)
    pss: time = 44.08 us    (44.1 %), step = 4.984 ps    (4.98 u%)
    pss: time = 44.16 us    (44.2 %), step = 2.869 ps    (2.87 u%)
    pss: time = 44.25 us    (44.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 44.34 us    (44.3 %), step = 4.697 ps     (4.7 u%)
    pss: time = 44.43 us    (44.4 %), step = 5.315 ps    (5.32 u%)
    pss: time = 44.51 us    (44.5 %), step = 2.556 ps    (2.56 u%)
    pss: time = 44.6 us     (44.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 44.69 us    (44.7 %), step = 7.902 ps     (7.9 u%)
    pss: time = 44.78 us    (44.8 %), step = 3.642 ps    (3.64 u%)
    pss: time = 44.86 us    (44.9 %), step = 6.555 ps    (6.55 u%)
    pss: time = 44.95 us      (45 %), step = 3.147 ps    (3.15 u%)
    pss: time = 45.04 us      (45 %), step = 8.889 ps    (8.89 u%)
    pss: time = 45.13 us    (45.1 %), step = 3.042 ps    (3.04 u%)
    pss: time = 45.21 us    (45.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 45.3 us     (45.3 %), step = 1.73 ps     (1.73 u%)
    pss: time = 45.38 us    (45.4 %), step = 5.282 ps    (5.28 u%)
    pss: time = 45.47 us    (45.5 %), step = 4.832 ps    (4.83 u%)
    pss: time = 45.56 us    (45.6 %), step = 4.038 ps    (4.04 u%)
    pss: time = 45.64 us    (45.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 45.73 us    (45.7 %), step = 2.838 ps    (2.84 u%)
    pss: time = 45.82 us    (45.8 %), step = 1.915 ps    (1.92 u%)
    pss: time = 45.91 us    (45.9 %), step = 4.404 ps     (4.4 u%)
    pss: time = 45.99 us      (46 %), step = 8.889 ps    (8.89 u%)
    pss: time = 46.08 us    (46.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 46.17 us    (46.2 %), step = 4.789 ps    (4.79 u%)
    pss: time = 46.26 us    (46.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 46.34 us    (46.3 %), step = 3.21 ps     (3.21 u%)
    pss: time = 46.43 us    (46.4 %), step = 2.382 ps    (2.38 u%)
    pss: time = 46.52 us    (46.5 %), step = 6.617 ps    (6.62 u%)
    pss: time = 46.6 us     (46.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 46.69 us    (46.7 %), step = 3.806 ps    (3.81 u%)
    pss: time = 46.78 us    (46.8 %), step = 1.774 ps    (1.77 u%)
    pss: time = 46.86 us    (46.9 %), step = 7.252 ps    (7.25 u%)
    pss: time = 46.95 us      (47 %), step = 2.974 ps    (2.97 u%)
    pss: time = 47.04 us      (47 %), step = 4.406 ps    (4.41 u%)
    pss: time = 47.13 us    (47.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 47.21 us    (47.2 %), step = 6.227 ps    (6.23 u%)
    pss: time = 47.3 us     (47.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 47.39 us    (47.4 %), step = 4.879 ps    (4.88 u%)
    pss: time = 47.48 us    (47.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 47.5 us     (47.5 %), step = 1.01 ps     (1.01 u%)
    pss: time = 47.59 us    (47.6 %), step = 7.692 ps    (7.69 u%)
    pss: time = 47.68 us    (47.7 %), step = 3.101 ps     (3.1 u%)
    pss: time = 47.76 us    (47.8 %), step = 1.989 ps    (1.99 u%)
    pss: time = 47.85 us    (47.9 %), step = 3.811 ps    (3.81 u%)
    pss: time = 47.94 us    (47.9 %), step = 3.882 ps    (3.88 u%)
    pss: time = 48.02 us      (48 %), step = 8.889 ps    (8.89 u%)
    pss: time = 48.11 us    (48.1 %), step = 4.718 ps    (4.72 u%)
    pss: time = 48.2 us     (48.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 48.29 us    (48.3 %), step = 3.938 ps    (3.94 u%)
    pss: time = 48.37 us    (48.4 %), step = 1.867 ps    (1.87 u%)
    pss: time = 48.46 us    (48.5 %), step = 4.031 ps    (4.03 u%)
    pss: time = 48.55 us    (48.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 48.64 us    (48.6 %), step = 6.408 ps    (6.41 u%)
    pss: time = 48.73 us    (48.7 %), step = 4.295 ps     (4.3 u%)
    pss: time = 48.81 us    (48.8 %), step = 1.992 ps    (1.99 u%)
    pss: time = 48.9 us     (48.9 %), step = 2.73 ps     (2.73 u%)
    pss: time = 48.99 us      (49 %), step = 3.72 ps     (3.72 u%)
    pss: time = 49.08 us    (49.1 %), step = 2.466 ps    (2.47 u%)
    pss: time = 49.16 us    (49.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 49.25 us    (49.3 %), step = 4.679 ps    (4.68 u%)
    pss: time = 49.34 us    (49.3 %), step = 4.602 ps     (4.6 u%)
    pss: time = 49.43 us    (49.4 %), step = 2.968 ps    (2.97 u%)
    pss: time = 49.51 us    (49.5 %), step = 3.013 ps    (3.01 u%)
    pss: time = 49.6 us     (49.6 %), step = 4.171 ps    (4.17 u%)
    pss: time = 49.69 us    (49.7 %), step = 3.37 ps     (3.37 u%)
    pss: time = 49.78 us    (49.8 %), step = 6.492 ps    (6.49 u%)
    pss: time = 49.86 us    (49.9 %), step = 4.402 ps     (4.4 u%)
    pss: time = 49.95 us    (49.9 %), step = 2.777 ps    (2.78 u%)
    pss: time = 50.04 us      (50 %), step = 4.346 ps    (4.35 u%)
    pss: time = 50.13 us    (50.1 %), step = 5.025 ps    (5.03 u%)
    pss: time = 50.21 us    (50.2 %), step = 4.899 ps     (4.9 u%)
    pss: time = 50.3 us     (50.3 %), step = 2.317 ps    (2.32 u%)
    pss: time = 50.39 us    (50.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 50.48 us    (50.5 %), step = 4.38 ps     (4.38 u%)
    pss: time = 50.56 us    (50.6 %), step = 2.669 ps    (2.67 u%)
    pss: time = 50.65 us    (50.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 50.74 us    (50.7 %), step = 3.598 ps     (3.6 u%)
    pss: time = 50.83 us    (50.8 %), step = 3.051 ps    (3.05 u%)
    pss: time = 50.91 us    (50.9 %), step = 3.508 ps    (3.51 u%)
    pss: time = 51 us         (51 %), step = 3.023 ps    (3.02 u%)
    pss: time = 51.09 us    (51.1 %), step = 4.335 ps    (4.33 u%)
    pss: time = 51.18 us    (51.2 %), step = 3.724 ps    (3.72 u%)
    pss: time = 51.26 us    (51.3 %), step = 2.871 ps    (2.87 u%)
    pss: time = 51.35 us    (51.4 %), step = 2.505 ps    (2.51 u%)
    pss: time = 51.44 us    (51.4 %), step = 2.962 ps    (2.96 u%)
    pss: time = 51.53 us    (51.5 %), step = 6.899 ps     (6.9 u%)
    pss: time = 51.62 us    (51.6 %), step = 4.273 ps    (4.27 u%)
    pss: time = 51.7 us     (51.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 51.79 us    (51.8 %), step = 2.819 ps    (2.82 u%)
    pss: time = 51.88 us    (51.9 %), step = 4.271 ps    (4.27 u%)
    pss: time = 51.96 us      (52 %), step = 4.139 ps    (4.14 u%)
    pss: time = 52.05 us    (52.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 52.14 us    (52.1 %), step = 4.582 ps    (4.58 u%)
    pss: time = 52.23 us    (52.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 52.31 us    (52.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 52.4 us     (52.4 %), step = 3.628 ps    (3.63 u%)
    pss: time = 52.49 us    (52.5 %), step = 4.839 ps    (4.84 u%)
    pss: time = 52.5 us     (52.5 %), step = 5.219 ps    (5.22 u%)
    pss: time = 52.59 us    (52.6 %), step = 2.657 ps    (2.66 u%)
    pss: time = 52.68 us    (52.7 %), step = 904.3 fs     (904 n%)
    pss: time = 52.76 us    (52.8 %), step = 1.115 ps    (1.12 u%)
    pss: time = 52.85 us    (52.8 %), step = 3.851 ps    (3.85 u%)
    pss: time = 52.94 us    (52.9 %), step = 4.61 ps     (4.61 u%)
    pss: time = 53.03 us      (53 %), step = 4.934 ps    (4.93 u%)
    pss: time = 53.11 us    (53.1 %), step = 1.092 ps    (1.09 u%)
    pss: time = 53.2 us     (53.2 %), step = 4.481 ps    (4.48 u%)
    pss: time = 53.29 us    (53.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 53.37 us    (53.4 %), step = 3.977 ps    (3.98 u%)
    pss: time = 53.46 us    (53.5 %), step = 5.239 ps    (5.24 u%)
    pss: time = 53.55 us    (53.5 %), step = 2.804 ps     (2.8 u%)
    pss: time = 53.64 us    (53.6 %), step = 4.129 ps    (4.13 u%)
    pss: time = 53.72 us    (53.7 %), step = 4.774 ps    (4.77 u%)
    pss: time = 53.81 us    (53.8 %), step = 3.125 ps    (3.13 u%)
    pss: time = 53.9 us     (53.9 %), step = 4.86 ps     (4.86 u%)
    pss: time = 53.99 us      (54 %), step = 4.21 ps     (4.21 u%)
    pss: time = 54.07 us    (54.1 %), step = 3.848 ps    (3.85 u%)
    pss: time = 54.16 us    (54.2 %), step = 4.046 ps    (4.05 u%)
    pss: time = 54.25 us    (54.2 %), step = 6.05 ps     (6.05 u%)
    pss: time = 54.34 us    (54.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 54.42 us    (54.4 %), step = 3.871 ps    (3.87 u%)
    pss: time = 54.51 us    (54.5 %), step = 3.861 ps    (3.86 u%)
    pss: time = 54.6 us     (54.6 %), step = 4.626 ps    (4.63 u%)
    pss: time = 54.69 us    (54.7 %), step = 3.366 ps    (3.37 u%)
    pss: time = 54.77 us    (54.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 54.86 us    (54.9 %), step = 4.535 ps    (4.53 u%)
    pss: time = 54.95 us    (54.9 %), step = 4.178 ps    (4.18 u%)
    pss: time = 55.04 us      (55 %), step = 3.146 ps    (3.15 u%)
    pss: time = 55.12 us    (55.1 %), step = 2.236 ps    (2.24 u%)
    pss: time = 55.21 us    (55.2 %), step = 4.747 ps    (4.75 u%)
    pss: time = 55.3 us     (55.3 %), step = 7.673 ps    (7.67 u%)
    pss: time = 55.39 us    (55.4 %), step = 3.226 ps    (3.23 u%)
    pss: time = 55.47 us    (55.5 %), step = 3.659 ps    (3.66 u%)
    pss: time = 55.56 us    (55.6 %), step = 8.766 ps    (8.77 u%)
    pss: time = 55.65 us    (55.6 %), step = 3.196 ps     (3.2 u%)
    pss: time = 55.74 us    (55.7 %), step = 4.812 ps    (4.81 u%)
    pss: time = 55.83 us    (55.8 %), step = 4.46 ps     (4.46 u%)
    pss: time = 55.91 us    (55.9 %), step = 4.363 ps    (4.36 u%)
    pss: time = 56 us         (56 %), step = 4.571 ps    (4.57 u%)
    pss: time = 56.09 us    (56.1 %), step = 2.758 ps    (2.76 u%)
    pss: time = 56.18 us    (56.2 %), step = 3.834 ps    (3.83 u%)
    pss: time = 56.27 us    (56.3 %), step = 3.561 ps    (3.56 u%)
    pss: time = 56.35 us    (56.4 %), step = 5.818 ps    (5.82 u%)
    pss: time = 56.44 us    (56.4 %), step = 2.576 ps    (2.58 u%)
    pss: time = 56.53 us    (56.5 %), step = 4.238 ps    (4.24 u%)
    pss: time = 56.62 us    (56.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 56.7 us     (56.7 %), step = 1.988 ps    (1.99 u%)
    pss: time = 56.79 us    (56.8 %), step = 4.226 ps    (4.23 u%)
    pss: time = 56.88 us    (56.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 56.97 us      (57 %), step = 4.684 ps    (4.68 u%)
    pss: time = 57.05 us    (57.1 %), step = 3.169 ps    (3.17 u%)
    pss: time = 57.14 us    (57.1 %), step = 6.813 ps    (6.81 u%)
    pss: time = 57.23 us    (57.2 %), step = 3.533 ps    (3.53 u%)
    pss: time = 57.32 us    (57.3 %), step = 2.571 ps    (2.57 u%)
    pss: time = 57.4 us     (57.4 %), step = 1.823 ps    (1.82 u%)
    pss: time = 57.49 us    (57.5 %), step = 1.904 ps     (1.9 u%)
    pss: time = 57.5 us     (57.5 %), step = 4.372 ps    (4.37 u%)
    pss: time = 57.59 us    (57.6 %), step = 4.912 ps    (4.91 u%)
    pss: time = 57.68 us    (57.7 %), step = 4.217 ps    (4.22 u%)
    pss: time = 57.76 us    (57.8 %), step = 2.626 ps    (2.63 u%)
    pss: time = 57.85 us    (57.9 %), step = 3.618 ps    (3.62 u%)
    pss: time = 57.94 us    (57.9 %), step = 2.889 ps    (2.89 u%)
    pss: time = 58.03 us      (58 %), step = 5.759 ps    (5.76 u%)
    pss: time = 58.11 us    (58.1 %), step = 3.574 ps    (3.57 u%)
    pss: time = 58.2 us     (58.2 %), step = 4.785 ps    (4.78 u%)
    pss: time = 58.29 us    (58.3 %), step = 1.77 ps     (1.77 u%)
    pss: time = 58.38 us    (58.4 %), step = 4.509 ps    (4.51 u%)
    pss: time = 58.47 us    (58.5 %), step = 1.94 ps     (1.94 u%)
    pss: time = 58.55 us    (58.6 %), step = 4.91 ps     (4.91 u%)
    pss: time = 58.64 us    (58.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 58.73 us    (58.7 %), step = 3.733 ps    (3.73 u%)
    pss: time = 58.81 us    (58.8 %), step = 4.579 ps    (4.58 u%)
    pss: time = 58.9 us     (58.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 58.99 us      (59 %), step = 8.889 ps    (8.89 u%)
    pss: time = 59.08 us    (59.1 %), step = 4.22 ps     (4.22 u%)
    pss: time = 59.17 us    (59.2 %), step = 2.689 ps    (2.69 u%)
    pss: time = 59.25 us    (59.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 59.34 us    (59.3 %), step = 2.838 ps    (2.84 u%)
    pss: time = 59.43 us    (59.4 %), step = 2.858 ps    (2.86 u%)
    pss: time = 59.52 us    (59.5 %), step = 1.054 ps    (1.05 u%)
    pss: time = 59.6 us     (59.6 %), step = 1.992 ps    (1.99 u%)
    pss: time = 59.69 us    (59.7 %), step = 2.923 ps    (2.92 u%)
    pss: time = 59.78 us    (59.8 %), step = 4.765 ps    (4.76 u%)
    pss: time = 59.87 us    (59.9 %), step = 4.962 ps    (4.96 u%)
    pss: time = 59.96 us      (60 %), step = 2.535 ps    (2.53 u%)
    pss: time = 60.04 us      (60 %), step = 5.004 ps       (5 u%)
    pss: time = 60.13 us    (60.1 %), step = 3.651 ps    (3.65 u%)
    pss: time = 60.22 us    (60.2 %), step = 4.902 ps     (4.9 u%)
    pss: time = 60.31 us    (60.3 %), step = 4.639 ps    (4.64 u%)
    pss: time = 60.39 us    (60.4 %), step = 4.87 ps     (4.87 u%)
    pss: time = 60.48 us    (60.5 %), step = 4.761 ps    (4.76 u%)
    pss: time = 60.57 us    (60.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 60.66 us    (60.7 %), step = 4.701 ps     (4.7 u%)
    pss: time = 60.74 us    (60.7 %), step = 3.768 ps    (3.77 u%)
    pss: time = 60.83 us    (60.8 %), step = 4.949 ps    (4.95 u%)
    pss: time = 60.92 us    (60.9 %), step = 2.842 ps    (2.84 u%)
    pss: time = 61.01 us      (61 %), step = 8.889 ps    (8.89 u%)
    pss: time = 61.09 us    (61.1 %), step = 3.602 ps     (3.6 u%)
    pss: time = 61.18 us    (61.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 61.27 us    (61.3 %), step = 1.02 ps     (1.02 u%)
    pss: time = 61.36 us    (61.4 %), step = 3.479 ps    (3.48 u%)
    pss: time = 61.45 us    (61.4 %), step = 4.377 ps    (4.38 u%)
    pss: time = 61.53 us    (61.5 %), step = 1.934 ps    (1.93 u%)
    pss: time = 61.62 us    (61.6 %), step = 1.965 ps    (1.96 u%)
    pss: time = 61.71 us    (61.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 61.8 us     (61.8 %), step = 6.722 ps    (6.72 u%)
    pss: time = 61.88 us    (61.9 %), step = 3.698 ps     (3.7 u%)
    pss: time = 61.97 us      (62 %), step = 2.75 ps     (2.75 u%)
    pss: time = 62.06 us    (62.1 %), step = 2.376 ps    (2.38 u%)
    pss: time = 62.15 us    (62.1 %), step = 5.028 ps    (5.03 u%)
    pss: time = 62.23 us    (62.2 %), step = 5.099 ps     (5.1 u%)
    pss: time = 62.32 us    (62.3 %), step = 5.032 ps    (5.03 u%)
    pss: time = 62.41 us    (62.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 62.5 us     (62.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 62.59 us    (62.6 %), step = 3.536 ps    (3.54 u%)
    pss: time = 62.67 us    (62.7 %), step = 2.874 ps    (2.87 u%)
    pss: time = 62.76 us    (62.8 %), step = 4.496 ps     (4.5 u%)
    pss: time = 62.85 us    (62.8 %), step = 4.218 ps    (4.22 u%)
    pss: time = 62.93 us    (62.9 %), step = 3.21 ps     (3.21 u%)
    pss: time = 63.02 us      (63 %), step = 3.688 ps    (3.69 u%)
    pss: time = 63.11 us    (63.1 %), step = 4.847 ps    (4.85 u%)
    pss: time = 63.19 us    (63.2 %), step = 4.238 ps    (4.24 u%)
    pss: time = 63.28 us    (63.3 %), step = 3.896 ps     (3.9 u%)
    pss: time = 63.36 us    (63.4 %), step = 2.816 ps    (2.82 u%)
    pss: time = 63.45 us    (63.4 %), step = 928.1 fs     (928 n%)
    pss: time = 63.54 us    (63.5 %), step = 3.35 ps     (3.35 u%)
    pss: time = 63.62 us    (63.6 %), step = 8.526 ps    (8.53 u%)
    pss: time = 63.71 us    (63.7 %), step = 4.205 ps     (4.2 u%)
    pss: time = 63.8 us     (63.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 63.88 us    (63.9 %), step = 4.885 ps    (4.88 u%)
    pss: time = 63.97 us      (64 %), step = 5.187 ps    (5.19 u%)
    pss: time = 64.06 us    (64.1 %), step = 4.261 ps    (4.26 u%)
    pss: time = 64.14 us    (64.1 %), step = 3.095 ps    (3.09 u%)
    pss: time = 64.23 us    (64.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 64.32 us    (64.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 64.41 us    (64.4 %), step = 2.957 ps    (2.96 u%)
    pss: time = 64.49 us    (64.5 %), step = 1.116 ps    (1.12 u%)
    pss: time = 64.58 us    (64.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 64.67 us    (64.7 %), step = 4.324 ps    (4.32 u%)
    pss: time = 64.75 us    (64.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 64.84 us    (64.8 %), step = 1.93 ps     (1.93 u%)
    pss: time = 64.93 us    (64.9 %), step = 3.862 ps    (3.86 u%)
    pss: time = 65.02 us      (65 %), step = 8.889 ps    (8.89 u%)
    pss: time = 65.1 us     (65.1 %), step = 2.861 ps    (2.86 u%)
    pss: time = 65.19 us    (65.2 %), step = 3.079 ps    (3.08 u%)
    pss: time = 65.28 us    (65.3 %), step = 3.03 ps     (3.03 u%)
    pss: time = 65.37 us    (65.4 %), step = 3.184 ps    (3.18 u%)
    pss: time = 65.45 us    (65.5 %), step = 5.307 ps    (5.31 u%)
    pss: time = 65.54 us    (65.5 %), step = 4.626 ps    (4.63 u%)
    pss: time = 65.63 us    (65.6 %), step = 5.464 ps    (5.46 u%)
    pss: time = 65.71 us    (65.7 %), step = 4.721 ps    (4.72 u%)
    pss: time = 65.8 us     (65.8 %), step = 4.49 ps     (4.49 u%)
    pss: time = 65.89 us    (65.9 %), step = 1.109 ps    (1.11 u%)
    pss: time = 65.98 us      (66 %), step = 4.383 ps    (4.38 u%)
    pss: time = 66.06 us    (66.1 %), step = 1.119 ps    (1.12 u%)
    pss: time = 66.15 us    (66.2 %), step = 5.275 ps    (5.27 u%)
    pss: time = 66.24 us    (66.2 %), step = 4.554 ps    (4.55 u%)
    pss: time = 66.33 us    (66.3 %), step = 4.988 ps    (4.99 u%)
    pss: time = 66.41 us    (66.4 %), step = 1.182 ps    (1.18 u%)
    pss: time = 66.5 us     (66.5 %), step = 5.546 ps    (5.55 u%)
    pss: time = 66.59 us    (66.6 %), step = 4.832 ps    (4.83 u%)
    pss: time = 66.67 us    (66.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 66.76 us    (66.8 %), step = 3.822 ps    (3.82 u%)
    pss: time = 66.85 us    (66.8 %), step = 3.54 ps     (3.54 u%)
    pss: time = 66.94 us    (66.9 %), step = 4.988 ps    (4.99 u%)
    pss: time = 67.03 us      (67 %), step = 4.919 ps    (4.92 u%)
    pss: time = 67.11 us    (67.1 %), step = 2.618 ps    (2.62 u%)
    pss: time = 67.2 us     (67.2 %), step = 3.708 ps    (3.71 u%)
    pss: time = 67.29 us    (67.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 67.37 us    (67.4 %), step = 3.686 ps    (3.69 u%)
    pss: time = 67.46 us    (67.5 %), step = 2.758 ps    (2.76 u%)
    pss: time = 67.5 us     (67.5 %), step = 8.515 ps    (8.51 u%)
    pss: time = 67.59 us    (67.6 %), step = 4.358 ps    (4.36 u%)
    pss: time = 67.67 us    (67.7 %), step = 5.054 ps    (5.05 u%)
    pss: time = 67.76 us    (67.8 %), step = 2.092 ps    (2.09 u%)
    pss: time = 67.85 us    (67.8 %), step = 6.535 ps    (6.53 u%)
    pss: time = 67.94 us    (67.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 68.02 us      (68 %), step = 6.597 ps     (6.6 u%)
    pss: time = 68.11 us    (68.1 %), step = 2.861 ps    (2.86 u%)
    pss: time = 68.2 us     (68.2 %), step = 3.122 ps    (3.12 u%)
    pss: time = 68.29 us    (68.3 %), step = 2.746 ps    (2.75 u%)
    pss: time = 68.37 us    (68.4 %), step = 4.388 ps    (4.39 u%)
    pss: time = 68.46 us    (68.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 68.55 us    (68.5 %), step = 4.846 ps    (4.85 u%)
    pss: time = 68.63 us    (68.6 %), step = 4.465 ps    (4.47 u%)
    pss: time = 68.72 us    (68.7 %), step = 3.069 ps    (3.07 u%)
    pss: time = 68.81 us    (68.8 %), step = 3.976 ps    (3.98 u%)
    pss: time = 68.9 us     (68.9 %), step = 2.002 ps       (2 u%)
    pss: time = 68.98 us      (69 %), step = 2.82 ps     (2.82 u%)
    pss: time = 69.07 us    (69.1 %), step = 8.245 ps    (8.24 u%)
    pss: time = 69.16 us    (69.2 %), step = 1.058 ps    (1.06 u%)
    pss: time = 69.25 us    (69.2 %), step = 3.893 ps    (3.89 u%)
    pss: time = 69.33 us    (69.3 %), step = 5.5 ps       (5.5 u%)
    pss: time = 69.42 us    (69.4 %), step = 3.173 ps    (3.17 u%)
    pss: time = 69.51 us    (69.5 %), step = 4.701 ps     (4.7 u%)
    pss: time = 69.59 us    (69.6 %), step = 2.653 ps    (2.65 u%)
    pss: time = 69.68 us    (69.7 %), step = 4.696 ps     (4.7 u%)
    pss: time = 69.77 us    (69.8 %), step = 3.271 ps    (3.27 u%)
    pss: time = 69.86 us    (69.9 %), step = 8.627 ps    (8.63 u%)
    pss: time = 69.95 us    (69.9 %), step = 3.338 ps    (3.34 u%)
    pss: time = 70.03 us      (70 %), step = 1.091 ps    (1.09 u%)
    pss: time = 70.12 us    (70.1 %), step = 4.387 ps    (4.39 u%)
    pss: time = 70.21 us    (70.2 %), step = 4.815 ps    (4.81 u%)
    pss: time = 70.3 us     (70.3 %), step = 4.589 ps    (4.59 u%)
    pss: time = 70.38 us    (70.4 %), step = 5.048 ps    (5.05 u%)
    pss: time = 70.47 us    (70.5 %), step = 2.87 ps     (2.87 u%)
    pss: time = 70.56 us    (70.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 70.65 us    (70.6 %), step = 4.473 ps    (4.47 u%)
    pss: time = 70.73 us    (70.7 %), step = 5.285 ps    (5.28 u%)
    pss: time = 70.82 us    (70.8 %), step = 4.462 ps    (4.46 u%)
    pss: time = 70.91 us    (70.9 %), step = 3.789 ps    (3.79 u%)
    pss: time = 70.99 us      (71 %), step = 3.329 ps    (3.33 u%)
    pss: time = 71.08 us    (71.1 %), step = 4.809 ps    (4.81 u%)
    pss: time = 71.17 us    (71.2 %), step = 3.179 ps    (3.18 u%)
    pss: time = 71.26 us    (71.3 %), step = 5.234 ps    (5.23 u%)
    pss: time = 71.34 us    (71.3 %), step = 2.839 ps    (2.84 u%)
    pss: time = 71.43 us    (71.4 %), step = 4.95 ps     (4.95 u%)
    pss: time = 71.52 us    (71.5 %), step = 3.194 ps    (3.19 u%)
    pss: time = 71.6 us     (71.6 %), step = 1.163 ps    (1.16 u%)
    pss: time = 71.69 us    (71.7 %), step = 5.94 ps     (5.94 u%)
    pss: time = 71.78 us    (71.8 %), step = 5.115 ps    (5.12 u%)
    pss: time = 71.86 us    (71.9 %), step = 5.565 ps    (5.56 u%)
    pss: time = 71.95 us      (72 %), step = 2.61 ps     (2.61 u%)
    pss: time = 72.04 us      (72 %), step = 3.308 ps    (3.31 u%)
    pss: time = 72.13 us    (72.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 72.21 us    (72.2 %), step = 1.815 ps    (1.82 u%)
    pss: time = 72.3 us     (72.3 %), step = 5.415 ps    (5.42 u%)
    pss: time = 72.39 us    (72.4 %), step = 2.197 ps     (2.2 u%)
    pss: time = 72.48 us    (72.5 %), step = 3.871 ps    (3.87 u%)
    pss: time = 72.5 us     (72.5 %), step = 4.451 ps    (4.45 u%)
    pss: time = 72.59 us    (72.6 %), step = 6.723 ps    (6.72 u%)
    pss: time = 72.68 us    (72.7 %), step = 2.84 ps     (2.84 u%)
    pss: time = 72.76 us    (72.8 %), step = 4.634 ps    (4.63 u%)
    pss: time = 72.85 us    (72.9 %), step = 2.785 ps    (2.79 u%)
    pss: time = 72.94 us    (72.9 %), step = 4.412 ps    (4.41 u%)
    pss: time = 73.03 us      (73 %), step = 3.001 ps       (3 u%)
    pss: time = 73.12 us    (73.1 %), step = 5.252 ps    (5.25 u%)
    pss: time = 73.2 us     (73.2 %), step = 3.465 ps    (3.46 u%)
    pss: time = 73.29 us    (73.3 %), step = 5.546 ps    (5.55 u%)
    pss: time = 73.38 us    (73.4 %), step = 4.136 ps    (4.14 u%)
    pss: time = 73.47 us    (73.5 %), step = 4.675 ps    (4.68 u%)
    pss: time = 73.55 us    (73.6 %), step = 6.419 ps    (6.42 u%)
    pss: time = 73.64 us    (73.6 %), step = 1.984 ps    (1.98 u%)
    pss: time = 73.73 us    (73.7 %), step = 2.244 ps    (2.24 u%)
    pss: time = 73.82 us    (73.8 %), step = 5.601 ps     (5.6 u%)
    pss: time = 73.9 us     (73.9 %), step = 4.336 ps    (4.34 u%)
    pss: time = 73.99 us      (74 %), step = 5.088 ps    (5.09 u%)
    pss: time = 74.08 us    (74.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 74.17 us    (74.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 74.25 us    (74.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 74.34 us    (74.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 74.43 us    (74.4 %), step = 4.197 ps     (4.2 u%)
    pss: time = 74.51 us    (74.5 %), step = 4.226 ps    (4.23 u%)
    pss: time = 74.6 us     (74.6 %), step = 5.767 ps    (5.77 u%)
    pss: time = 74.69 us    (74.7 %), step = 2.6 ps       (2.6 u%)
    pss: time = 74.78 us    (74.8 %), step = 6.522 ps    (6.52 u%)
    pss: time = 74.87 us    (74.9 %), step = 3.243 ps    (3.24 u%)
    pss: time = 74.95 us      (75 %), step = 2.762 ps    (2.76 u%)
    pss: time = 75.04 us      (75 %), step = 8.241 ps    (8.24 u%)
    pss: time = 75.13 us    (75.1 %), step = 4.99 ps     (4.99 u%)
    pss: time = 75.22 us    (75.2 %), step = 2.716 ps    (2.72 u%)
    pss: time = 75.3 us     (75.3 %), step = 2.734 ps    (2.73 u%)
    pss: time = 75.39 us    (75.4 %), step = 7.975 ps    (7.97 u%)
    pss: time = 75.48 us    (75.5 %), step = 3.827 ps    (3.83 u%)
    pss: time = 75.57 us    (75.6 %), step = 2.724 ps    (2.72 u%)
    pss: time = 75.65 us    (75.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 75.74 us    (75.7 %), step = 5.074 ps    (5.07 u%)
    pss: time = 75.83 us    (75.8 %), step = 2.792 ps    (2.79 u%)
    pss: time = 75.92 us    (75.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 76 us         (76 %), step = 7.806 ps    (7.81 u%)
    pss: time = 76.09 us    (76.1 %), step = 3.642 ps    (3.64 u%)
    pss: time = 76.18 us    (76.2 %), step = 5.504 ps     (5.5 u%)
    pss: time = 76.27 us    (76.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 76.36 us    (76.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 76.44 us    (76.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 76.53 us    (76.5 %), step = 2.816 ps    (2.82 u%)
    pss: time = 76.62 us    (76.6 %), step = 4.822 ps    (4.82 u%)
    pss: time = 76.7 us     (76.7 %), step = 5.605 ps     (5.6 u%)
    pss: time = 76.79 us    (76.8 %), step = 3.673 ps    (3.67 u%)
    pss: time = 76.88 us    (76.9 %), step = 3.656 ps    (3.66 u%)
    pss: time = 76.97 us      (77 %), step = 8.889 ps    (8.89 u%)
    pss: time = 77.05 us    (77.1 %), step = 6.327 ps    (6.33 u%)
    pss: time = 77.14 us    (77.1 %), step = 4.732 ps    (4.73 u%)
    pss: time = 77.23 us    (77.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 77.32 us    (77.3 %), step = 3.697 ps     (3.7 u%)
    pss: time = 77.41 us    (77.4 %), step = 8.517 ps    (8.52 u%)
    pss: time = 77.49 us    (77.5 %), step = 3.59 ps     (3.59 u%)
    pss: time = 77.5 us     (77.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 77.59 us    (77.6 %), step = 4.896 ps     (4.9 u%)
    pss: time = 77.67 us    (77.7 %), step = 5.383 ps    (5.38 u%)
    pss: time = 77.76 us    (77.8 %), step = 2.888 ps    (2.89 u%)
    pss: time = 77.85 us    (77.8 %), step = 4.957 ps    (4.96 u%)
    pss: time = 77.94 us    (77.9 %), step = 3.102 ps     (3.1 u%)
    pss: time = 78.03 us      (78 %), step = 4.554 ps    (4.55 u%)
    pss: time = 78.11 us    (78.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 78.2 us     (78.2 %), step = 3.828 ps    (3.83 u%)
    pss: time = 78.29 us    (78.3 %), step = 1.99 ps     (1.99 u%)
    pss: time = 78.38 us    (78.4 %), step = 2.771 ps    (2.77 u%)
    pss: time = 78.46 us    (78.5 %), step = 5.087 ps    (5.09 u%)
    pss: time = 78.55 us    (78.5 %), step = 1.385 ps    (1.38 u%)
    pss: time = 78.64 us    (78.6 %), step = 2.595 ps     (2.6 u%)
    pss: time = 78.72 us    (78.7 %), step = 995.7 fs     (996 n%)
    pss: time = 78.81 us    (78.8 %), step = 4.724 ps    (4.72 u%)
    pss: time = 78.9 us     (78.9 %), step = 5.116 ps    (5.12 u%)
    pss: time = 78.99 us      (79 %), step = 8.889 ps    (8.89 u%)
    pss: time = 79.08 us    (79.1 %), step = 3.95 ps     (3.95 u%)
    pss: time = 79.16 us    (79.2 %), step = 4.828 ps    (4.83 u%)
    pss: time = 79.25 us    (79.2 %), step = 3.603 ps     (3.6 u%)
    pss: time = 79.34 us    (79.3 %), step = 1.776 ps    (1.78 u%)
    pss: time = 79.42 us    (79.4 %), step = 1.908 ps    (1.91 u%)
    pss: time = 79.51 us    (79.5 %), step = 7.719 ps    (7.72 u%)
    pss: time = 79.6 us     (79.6 %), step = 2.852 ps    (2.85 u%)
    pss: time = 79.69 us    (79.7 %), step = 5.084 ps    (5.08 u%)
    pss: time = 79.77 us    (79.8 %), step = 4.814 ps    (4.81 u%)
    pss: time = 79.86 us    (79.9 %), step = 4.646 ps    (4.65 u%)
    pss: time = 79.95 us    (79.9 %), step = 3.306 ps    (3.31 u%)
    pss: time = 80.03 us      (80 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.12 us    (80.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.21 us    (80.2 %), step = 2.624 ps    (2.62 u%)
    pss: time = 80.3 us     (80.3 %), step = 1.86 ps     (1.86 u%)
    pss: time = 80.39 us    (80.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.47 us    (80.5 %), step = 4.752 ps    (4.75 u%)
    pss: time = 80.56 us    (80.6 %), step = 3.703 ps     (3.7 u%)
    pss: time = 80.65 us    (80.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.74 us    (80.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.82 us    (80.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 80.91 us    (80.9 %), step = 3.995 ps       (4 u%)
    pss: time = 81 us         (81 %), step = 3.551 ps    (3.55 u%)
    pss: time = 81.09 us    (81.1 %), step = 1.022 ps    (1.02 u%)
    pss: time = 81.17 us    (81.2 %), step = 3.61 ps     (3.61 u%)
    pss: time = 81.26 us    (81.3 %), step = 5.101 ps     (5.1 u%)
    pss: time = 81.35 us    (81.3 %), step = 4.992 ps    (4.99 u%)
    pss: time = 81.44 us    (81.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 81.53 us    (81.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 81.61 us    (81.6 %), step = 4.735 ps    (4.73 u%)
    pss: time = 81.7 us     (81.7 %), step = 2.972 ps    (2.97 u%)
    pss: time = 81.79 us    (81.8 %), step = 3.967 ps    (3.97 u%)
    pss: time = 81.88 us    (81.9 %), step = 3.467 ps    (3.47 u%)
    pss: time = 81.97 us      (82 %), step = 5.709 ps    (5.71 u%)
    pss: time = 82.06 us    (82.1 %), step = 3.196 ps     (3.2 u%)
    pss: time = 82.14 us    (82.1 %), step = 5.685 ps    (5.68 u%)
    pss: time = 82.23 us    (82.2 %), step = 5.074 ps    (5.07 u%)
    pss: time = 82.32 us    (82.3 %), step = 1.046 ps    (1.05 u%)
    pss: time = 82.41 us    (82.4 %), step = 2.857 ps    (2.86 u%)
    pss: time = 82.5 us     (82.5 %), step = 4.856 ps    (4.86 u%)
    pss: time = 82.5 us     (82.5 %), step = 3.683 ps    (3.68 u%)
    pss: time = 82.59 us    (82.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 82.68 us    (82.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 82.76 us    (82.8 %), step = 6.145 ps    (6.14 u%)
    pss: time = 82.85 us    (82.8 %), step = 2.6 ps       (2.6 u%)
    pss: time = 82.94 us    (82.9 %), step = 3.132 ps    (3.13 u%)
    pss: time = 83.03 us      (83 %), step = 4.743 ps    (4.74 u%)
    pss: time = 83.11 us    (83.1 %), step = 5.081 ps    (5.08 u%)
    pss: time = 83.2 us     (83.2 %), step = 3.261 ps    (3.26 u%)
    pss: time = 83.29 us    (83.3 %), step = 4.115 ps    (4.12 u%)
    pss: time = 83.38 us    (83.4 %), step = 4.281 ps    (4.28 u%)
    pss: time = 83.46 us    (83.5 %), step = 6.454 ps    (6.45 u%)
    pss: time = 83.55 us    (83.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 83.64 us    (83.6 %), step = 5.735 ps    (5.73 u%)
    pss: time = 83.73 us    (83.7 %), step = 4.211 ps    (4.21 u%)
    pss: time = 83.81 us    (83.8 %), step = 3.979 ps    (3.98 u%)
    pss: time = 83.9 us     (83.9 %), step = 2.848 ps    (2.85 u%)
    pss: time = 83.99 us      (84 %), step = 3.59 ps     (3.59 u%)
    pss: time = 84.07 us    (84.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 84.16 us    (84.2 %), step = 1.914 ps    (1.91 u%)
    pss: time = 84.25 us    (84.2 %), step = 5.018 ps    (5.02 u%)
    pss: time = 84.34 us    (84.3 %), step = 4.83 ps     (4.83 u%)
    pss: time = 84.43 us    (84.4 %), step = 918.9 fs     (919 n%)
    pss: time = 84.51 us    (84.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 84.6 us     (84.6 %), step = 2.775 ps    (2.78 u%)
    pss: time = 84.69 us    (84.7 %), step = 1.09 ps     (1.09 u%)
    pss: time = 84.78 us    (84.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 84.86 us    (84.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 84.95 us      (85 %), step = 6.392 ps    (6.39 u%)
    pss: time = 85.04 us      (85 %), step = 5.116 ps    (5.12 u%)
    pss: time = 85.13 us    (85.1 %), step = 2.996 ps       (3 u%)
    pss: time = 85.21 us    (85.2 %), step = 2.686 ps    (2.69 u%)
    pss: time = 85.3 us     (85.3 %), step = 3.491 ps    (3.49 u%)
    pss: time = 85.39 us    (85.4 %), step = 2.915 ps    (2.92 u%)
    pss: time = 85.48 us    (85.5 %), step = 4.486 ps    (4.49 u%)
    pss: time = 85.57 us    (85.6 %), step = 3.813 ps    (3.81 u%)
    pss: time = 85.65 us    (85.7 %), step = 2.904 ps     (2.9 u%)
    pss: time = 85.74 us    (85.7 %), step = 3.067 ps    (3.07 u%)
    pss: time = 85.83 us    (85.8 %), step = 3.632 ps    (3.63 u%)
    pss: time = 85.91 us    (85.9 %), step = 8.889 ps    (8.89 u%)
    pss: time = 86 us         (86 %), step = 2.7 ps       (2.7 u%)
    pss: time = 86.09 us    (86.1 %), step = 4.949 ps    (4.95 u%)
    pss: time = 86.18 us    (86.2 %), step = 2.174 ps    (2.17 u%)
    pss: time = 86.26 us    (86.3 %), step = 4.904 ps     (4.9 u%)
    pss: time = 86.35 us    (86.4 %), step = 3.595 ps     (3.6 u%)
    pss: time = 86.44 us    (86.4 %), step = 3.865 ps    (3.86 u%)
    pss: time = 86.53 us    (86.5 %), step = 3.082 ps    (3.08 u%)
    pss: time = 86.62 us    (86.6 %), step = 4.588 ps    (4.59 u%)
    pss: time = 86.7 us     (86.7 %), step = 4.523 ps    (4.52 u%)
    pss: time = 86.79 us    (86.8 %), step = 3.864 ps    (3.86 u%)
    pss: time = 86.88 us    (86.9 %), step = 4.246 ps    (4.25 u%)
    pss: time = 86.97 us      (87 %), step = 4.905 ps    (4.91 u%)
    pss: time = 87.06 us    (87.1 %), step = 3.864 ps    (3.86 u%)
    pss: time = 87.15 us    (87.1 %), step = 4.568 ps    (4.57 u%)
    pss: time = 87.23 us    (87.2 %), step = 4.231 ps    (4.23 u%)
    pss: time = 87.32 us    (87.3 %), step = 7.728 ps    (7.73 u%)
    pss: time = 87.41 us    (87.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 87.5 us     (87.5 %), step = 5.461 ps    (5.46 u%)
    pss: time = 87.5 us     (87.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 87.59 us    (87.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 87.67 us    (87.7 %), step = 3.31 ps     (3.31 u%)
    pss: time = 87.76 us    (87.8 %), step = 4.644 ps    (4.64 u%)
    pss: time = 87.85 us    (87.8 %), step = 4.004 ps       (4 u%)
    pss: time = 87.94 us    (87.9 %), step = 4.813 ps    (4.81 u%)
    pss: time = 88.02 us      (88 %), step = 3.52 ps     (3.52 u%)
    pss: time = 88.11 us    (88.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 88.2 us     (88.2 %), step = 2.832 ps    (2.83 u%)
    pss: time = 88.29 us    (88.3 %), step = 1.794 ps    (1.79 u%)
    pss: time = 88.38 us    (88.4 %), step = 3.197 ps     (3.2 u%)
    pss: time = 88.46 us    (88.5 %), step = 6.582 ps    (6.58 u%)
    pss: time = 88.55 us    (88.5 %), step = 5.003 ps       (5 u%)
    pss: time = 88.64 us    (88.6 %), step = 4.07 ps     (4.07 u%)
    pss: time = 88.73 us    (88.7 %), step = 4.958 ps    (4.96 u%)
    pss: time = 88.81 us    (88.8 %), step = 4.734 ps    (4.73 u%)
    pss: time = 88.9 us     (88.9 %), step = 5.408 ps    (5.41 u%)
    pss: time = 88.99 us      (89 %), step = 4.179 ps    (4.18 u%)
    pss: time = 89.08 us    (89.1 %), step = 2.236 ps    (2.24 u%)
    pss: time = 89.16 us    (89.2 %), step = 1.069 ps    (1.07 u%)
    pss: time = 89.25 us    (89.3 %), step = 3.292 ps    (3.29 u%)
    pss: time = 89.34 us    (89.3 %), step = 3.24 ps     (3.24 u%)
    pss: time = 89.43 us    (89.4 %), step = 4.603 ps     (4.6 u%)
    pss: time = 89.52 us    (89.5 %), step = 2.854 ps    (2.85 u%)
    pss: time = 89.6 us     (89.6 %), step = 1.935 ps    (1.94 u%)
    pss: time = 89.69 us    (89.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 89.78 us    (89.8 %), step = 3.661 ps    (3.66 u%)
    pss: time = 89.87 us    (89.9 %), step = 3.616 ps    (3.62 u%)
    pss: time = 89.95 us      (90 %), step = 4.105 ps     (4.1 u%)
    pss: time = 90.04 us      (90 %), step = 3.985 ps    (3.99 u%)
    pss: time = 90.13 us    (90.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 90.22 us    (90.2 %), step = 2.557 ps    (2.56 u%)
    pss: time = 90.31 us    (90.3 %), step = 1.011 ps    (1.01 u%)
    pss: time = 90.4 us     (90.4 %), step = 3.387 ps    (3.39 u%)
    pss: time = 90.48 us    (90.5 %), step = 4.554 ps    (4.55 u%)
    pss: time = 90.57 us    (90.6 %), step = 4.203 ps     (4.2 u%)
    pss: time = 90.66 us    (90.7 %), step = 5.234 ps    (5.23 u%)
    pss: time = 90.75 us    (90.7 %), step = 5.672 ps    (5.67 u%)
    pss: time = 90.84 us    (90.8 %), step = 3.102 ps     (3.1 u%)
    pss: time = 90.92 us    (90.9 %), step = 2.87 ps     (2.87 u%)
    pss: time = 91.01 us      (91 %), step = 3.58 ps     (3.58 u%)
    pss: time = 91.1 us     (91.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 91.19 us    (91.2 %), step = 5.188 ps    (5.19 u%)
    pss: time = 91.27 us    (91.3 %), step = 2.952 ps    (2.95 u%)
    pss: time = 91.36 us    (91.4 %), step = 5.5 ps       (5.5 u%)
    pss: time = 91.45 us    (91.4 %), step = 4.714 ps    (4.71 u%)
    pss: time = 91.54 us    (91.5 %), step = 4.572 ps    (4.57 u%)
    pss: time = 91.62 us    (91.6 %), step = 2.574 ps    (2.57 u%)
    pss: time = 91.71 us    (91.7 %), step = 4.224 ps    (4.22 u%)
    pss: time = 91.8 us     (91.8 %), step = 1.89 ps     (1.89 u%)
    pss: time = 91.89 us    (91.9 %), step = 1.017 ps    (1.02 u%)
    pss: time = 91.97 us      (92 %), step = 4.35 ps     (4.35 u%)
    pss: time = 92.06 us    (92.1 %), step = 3.496 ps     (3.5 u%)
    pss: time = 92.15 us    (92.1 %), step = 2.965 ps    (2.96 u%)
    pss: time = 92.24 us    (92.2 %), step = 5.095 ps     (5.1 u%)
    pss: time = 92.32 us    (92.3 %), step = 4.281 ps    (4.28 u%)
    pss: time = 92.41 us    (92.4 %), step = 4.514 ps    (4.51 u%)
    pss: time = 92.5 us     (92.5 %), step = 8.427 ps    (8.43 u%)
    pss: time = 92.5 us     (92.5 %), step = 2.98 ps     (2.98 u%)
    pss: time = 92.59 us    (92.6 %), step = 1.138 ps    (1.14 u%)
    pss: time = 92.68 us    (92.7 %), step = 5.304 ps     (5.3 u%)
    pss: time = 92.76 us    (92.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 92.85 us    (92.9 %), step = 5.075 ps    (5.07 u%)
    pss: time = 92.94 us    (92.9 %), step = 3.617 ps    (3.62 u%)
    pss: time = 93.03 us      (93 %), step = 6.505 ps     (6.5 u%)
    pss: time = 93.12 us    (93.1 %), step = 4.335 ps    (4.33 u%)
    pss: time = 93.2 us     (93.2 %), step = 1.111 ps    (1.11 u%)
    pss: time = 93.29 us    (93.3 %), step = 3.668 ps    (3.67 u%)
    pss: time = 93.38 us    (93.4 %), step = 4.099 ps     (4.1 u%)
    pss: time = 93.47 us    (93.5 %), step = 4.704 ps     (4.7 u%)
    pss: time = 93.55 us    (93.6 %), step = 8.889 ps    (8.89 u%)
    pss: time = 93.64 us    (93.6 %), step = 4.76 ps     (4.76 u%)
    pss: time = 93.73 us    (93.7 %), step = 915.6 fs     (916 n%)
    pss: time = 93.82 us    (93.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 93.9 us     (93.9 %), step = 4.413 ps    (4.41 u%)
    pss: time = 93.99 us      (94 %), step = 1.913 ps    (1.91 u%)
    pss: time = 94.08 us    (94.1 %), step = 3.829 ps    (3.83 u%)
    pss: time = 94.17 us    (94.2 %), step = 1.073 ps    (1.07 u%)
    pss: time = 94.25 us    (94.3 %), step = 1.987 ps    (1.99 u%)
    pss: time = 94.34 us    (94.3 %), step = 898.3 fs     (898 n%)
    pss: time = 94.43 us    (94.4 %), step = 2.23 ps     (2.23 u%)
    pss: time = 94.52 us    (94.5 %), step = 3.137 ps    (3.14 u%)
    pss: time = 94.61 us    (94.6 %), step = 6.788 ps    (6.79 u%)
    pss: time = 94.69 us    (94.7 %), step = 3.493 ps    (3.49 u%)
    pss: time = 94.78 us    (94.8 %), step = 3.696 ps     (3.7 u%)
    pss: time = 94.87 us    (94.9 %), step = 3.162 ps    (3.16 u%)
    pss: time = 94.96 us      (95 %), step = 5.642 ps    (5.64 u%)
    pss: time = 95.05 us      (95 %), step = 2.686 ps    (2.69 u%)
    pss: time = 95.13 us    (95.1 %), step = 4.593 ps    (4.59 u%)
    pss: time = 95.22 us    (95.2 %), step = 2.477 ps    (2.48 u%)
    pss: time = 95.31 us    (95.3 %), step = 8.02 ps     (8.02 u%)
    pss: time = 95.4 us     (95.4 %), step = 4.628 ps    (4.63 u%)
    pss: time = 95.48 us    (95.5 %), step = 3.856 ps    (3.86 u%)
    pss: time = 95.57 us    (95.6 %), step = 2.571 ps    (2.57 u%)
    pss: time = 95.66 us    (95.7 %), step = 2.79 ps     (2.79 u%)
    pss: time = 95.75 us    (95.7 %), step = 3.074 ps    (3.07 u%)
    pss: time = 95.83 us    (95.8 %), step = 4.346 ps    (4.35 u%)
    pss: time = 95.92 us    (95.9 %), step = 4.131 ps    (4.13 u%)
    pss: time = 96.01 us      (96 %), step = 8.889 ps    (8.89 u%)
    pss: time = 96.1 us     (96.1 %), step = 5.546 ps    (5.55 u%)
    pss: time = 96.19 us    (96.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 96.27 us    (96.3 %), step = 3.651 ps    (3.65 u%)
    pss: time = 96.36 us    (96.4 %), step = 8.889 ps    (8.89 u%)
    pss: time = 96.45 us    (96.4 %), step = 5.642 ps    (5.64 u%)
    pss: time = 96.54 us    (96.5 %), step = 2.897 ps     (2.9 u%)
    pss: time = 96.63 us    (96.6 %), step = 4.476 ps    (4.48 u%)
    pss: time = 96.71 us    (96.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 96.8 us     (96.8 %), step = 3.181 ps    (3.18 u%)
    pss: time = 96.89 us    (96.9 %), step = 3.574 ps    (3.57 u%)
    pss: time = 96.98 us      (97 %), step = 4.845 ps    (4.84 u%)
    pss: time = 97.06 us    (97.1 %), step = 4.872 ps    (4.87 u%)
    pss: time = 97.15 us    (97.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 97.24 us    (97.2 %), step = 8.889 ps    (8.89 u%)
    pss: time = 97.33 us    (97.3 %), step = 6.523 ps    (6.52 u%)
    pss: time = 97.42 us    (97.4 %), step = 4.203 ps     (4.2 u%)
    pss: time = 97.5 us     (97.5 %), step = 8.889 ps    (8.89 u%)
    pss: time = 97.59 us    (97.6 %), step = 2.06 ps     (2.06 u%)
    pss: time = 97.68 us    (97.7 %), step = 5.381 ps    (5.38 u%)
    pss: time = 97.76 us    (97.8 %), step = 2.988 ps    (2.99 u%)
    pss: time = 97.85 us    (97.8 %), step = 4.251 ps    (4.25 u%)
    pss: time = 97.94 us    (97.9 %), step = 5.148 ps    (5.15 u%)
    pss: time = 98.03 us      (98 %), step = 3.052 ps    (3.05 u%)
    pss: time = 98.11 us    (98.1 %), step = 3.533 ps    (3.53 u%)
    pss: time = 98.2 us     (98.2 %), step = 3.675 ps    (3.68 u%)
    pss: time = 98.29 us    (98.3 %), step = 4.424 ps    (4.42 u%)
    pss: time = 98.38 us    (98.4 %), step = 1.087 ps    (1.09 u%)
    pss: time = 98.47 us    (98.5 %), step = 1.851 ps    (1.85 u%)
    pss: time = 98.55 us    (98.6 %), step = 3.859 ps    (3.86 u%)
    pss: time = 98.64 us    (98.6 %), step = 4.476 ps    (4.48 u%)
    pss: time = 98.73 us    (98.7 %), step = 1.772 ps    (1.77 u%)
    pss: time = 98.82 us    (98.8 %), step = 8.889 ps    (8.89 u%)
    pss: time = 98.9 us     (98.9 %), step = 3.976 ps    (3.98 u%)
    pss: time = 98.99 us      (99 %), step = 4.1 ps       (4.1 u%)
    pss: time = 99.08 us    (99.1 %), step = 8.889 ps    (8.89 u%)
    pss: time = 99.17 us    (99.2 %), step = 1.001 ps       (1 u%)
    pss: time = 99.26 us    (99.3 %), step = 1.99 ps     (1.99 u%)
    pss: time = 99.34 us    (99.3 %), step = 8.889 ps    (8.89 u%)
    pss: time = 99.43 us    (99.4 %), step = 4.54 ps     (4.54 u%)
    pss: time = 99.52 us    (99.5 %), step = 1.021 ps    (1.02 u%)
    pss: time = 99.61 us    (99.6 %), step = 2.804 ps     (2.8 u%)
    pss: time = 99.69 us    (99.7 %), step = 8.889 ps    (8.89 u%)
    pss: time = 99.78 us    (99.8 %), step = 3.03 ps     (3.03 u%)
    pss: time = 99.87 us    (99.9 %), step = 3.44 ps     (3.44 u%)
    pss: time = 99.96 us     (100 %), step = 3.985 ps    (3.98 u%)
The Estimated oscillating frequency from Tstab Tran is = 6.4469 GHz .
Conv norm = 17.9e+03, max dI(V2:p) = 1.25543 A, took 11.3848 ks.
Important parameter values in pss iteration:
    start = 100.001 us
    outputstart = 0 s
    stop = 100.001 us
    period = 155.113 ps
    steadyratio = 100e-03
    step = 100 ns
    maxstep = 387.784 fs
    ic = all
    skipdc = no
    reltol = 10e-06
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    errpreset = conservative
    method = gear2only
    lteratio = 10
    relref = alllocal
    cmin = 0 F
    gmin = 1 pS
Notice from spectre during periodic steady state analysis `pss'.
    7 warnings suppressed.
`pss': time = (100.001 us -> 100.001 us)
    pss: time = 100 us      (2.53 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (7.69 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (12.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (17.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (22.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (27.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (32.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (37.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (42.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (47.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (52.7 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (57.6 %), step = 325.8 fs     (210 m%)
    pss: time = 100 us      (62.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (67.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (72.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (77.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (82.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (87.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (92.6 %), step = 387.8 fs     (250 m%)
    pss: time = 100 us      (97.6 %), step = 387.8 fs     (250 m%)
Conv norm = 132e+03, max dI(V2:p) = -1.25549 A, took 200 ms.
Conv norm = 135e-03, max dV(M12:int_d) = -3.50271 uV, took 200 ms.
Fundamental frequency is 6.44698 GHz.
Number of accepted pss steps =             20250424
Initial condition solution time: CPU = 5 ms, elapsed = 5.06687 ms.
pss: The steady-state solution was achieved in 3 iterations.
Number of accepted pss steps =             402
Total time required for pss analysis `pss': CPU = 11.3796 ks (3h 9m 40s), elapsed = 11.3895 ks (3h 9m 50s).
Time accumulated: CPU = 11.3836 ks (3h 9m 44s), elapsed = 11.3939 ks (3h 9m 54s).
Peak resident memory used = 85.7 Mbytes.
Notice from spectre.
    7 notices suppressed.
Periodic Noise Analysis `pnoise': freq = 6.44698 GHz + (1 kHz -> 1 GHz)
Using the operating-point information generated by PSS analysis `pss'.
The estimated line width of the oscillator is 11.8866 kHz.
    pnoise: freq = 1.468 kHz   (2.78 %), step = 108.4 Hz     (556 m%)
    pnoise: freq = 1.585 kHz   (3.33 %), step = 117.1 Hz     (556 m%)
    pnoise: freq = 1.711 kHz   (3.89 %), step = 126.4 Hz     (556 m%)
    pnoise: freq = 1.848 kHz   (4.44 %), step = 136.5 Hz     (556 m%)
    pnoise: freq = 1.995 kHz      (5 %), step = 147.4 Hz     (556 m%)
    pnoise: freq = 2.154 kHz   (5.56 %), step = 159.2 Hz     (556 m%)
    pnoise: freq = 2.326 kHz   (6.11 %), step = 171.9 Hz     (556 m%)
    pnoise: freq = 2.512 kHz   (6.67 %), step = 185.6 Hz     (556 m%)
    pnoise: freq = 2.712 kHz   (7.22 %), step = 200.4 Hz     (556 m%)
    pnoise: freq = 2.929 kHz   (7.78 %), step = 216.4 Hz     (556 m%)
    pnoise: freq = 3.162 kHz   (8.33 %), step = 233.6 Hz     (556 m%)
    pnoise: freq = 3.415 kHz   (8.89 %), step = 252.3 Hz     (556 m%)
    pnoise: freq = 3.687 kHz   (9.44 %), step = 272.4 Hz     (556 m%)
    pnoise: freq = 3.981 kHz     (10 %), step = 294.1 Hz     (556 m%)
    pnoise: freq = 4.299 kHz   (10.6 %), step = 317.6 Hz     (556 m%)
    pnoise: freq = 4.642 kHz   (11.1 %), step = 342.9 Hz     (556 m%)
    pnoise: freq = 5.012 kHz   (11.7 %), step = 370.3 Hz     (556 m%)
    pnoise: freq = 5.412 kHz   (12.2 %), step = 399.8 Hz     (556 m%)
    pnoise: freq = 5.843 kHz   (12.8 %), step = 431.7 Hz     (556 m%)
    pnoise: freq = 6.31 kHz    (13.3 %), step = 466.2 Hz     (556 m%)
    pnoise: freq = 6.813 kHz   (13.9 %), step = 503.3 Hz     (556 m%)
    pnoise: freq = 7.356 kHz   (14.4 %), step = 543.5 Hz     (556 m%)
    pnoise: freq = 7.943 kHz     (15 %), step = 586.9 Hz     (556 m%)
    pnoise: freq = 8.577 kHz   (15.6 %), step = 633.7 Hz     (556 m%)
    pnoise: freq = 9.261 kHz   (16.1 %), step = 684.2 Hz     (556 m%)
    pnoise: freq = 10 kHz      (16.7 %), step = 738.8 Hz     (556 m%)
    pnoise: freq = 10.8 kHz    (17.2 %), step = 797.8 Hz     (556 m%)
    pnoise: freq = 11.66 kHz   (17.8 %), step = 861.4 Hz     (556 m%)
    pnoise: freq = 12.59 kHz   (18.3 %), step = 930.1 Hz     (556 m%)
    pnoise: freq = 13.59 kHz   (18.9 %), step = 1.004 kHz    (556 m%)
    pnoise: freq = 14.68 kHz   (19.4 %), step = 1.084 kHz    (556 m%)
    pnoise: freq = 15.85 kHz     (20 %), step = 1.171 kHz    (556 m%)
    pnoise: freq = 17.11 kHz   (20.6 %), step = 1.264 kHz    (556 m%)
    pnoise: freq = 18.48 kHz   (21.1 %), step = 1.365 kHz    (556 m%)
    pnoise: freq = 19.95 kHz   (21.7 %), step = 1.474 kHz    (556 m%)
    pnoise: freq = 21.54 kHz   (22.2 %), step = 1.592 kHz    (556 m%)
    pnoise: freq = 23.26 kHz   (22.8 %), step = 1.719 kHz    (556 m%)
    pnoise: freq = 25.12 kHz   (23.3 %), step = 1.856 kHz    (556 m%)
    pnoise: freq = 27.12 kHz   (23.9 %), step = 2.004 kHz    (556 m%)
    pnoise: freq = 29.29 kHz   (24.4 %), step = 2.164 kHz    (556 m%)
    pnoise: freq = 31.62 kHz     (25 %), step = 2.336 kHz    (556 m%)
    pnoise: freq = 34.15 kHz   (25.6 %), step = 2.523 kHz    (556 m%)
    pnoise: freq = 36.87 kHz   (26.1 %), step = 2.724 kHz    (556 m%)
    pnoise: freq = 39.81 kHz   (26.7 %), step = 2.941 kHz    (556 m%)
    pnoise: freq = 42.99 kHz   (27.2 %), step = 3.176 kHz    (556 m%)
    pnoise: freq = 46.42 kHz   (27.8 %), step = 3.429 kHz    (556 m%)
    pnoise: freq = 50.12 kHz   (28.3 %), step = 3.703 kHz    (556 m%)
    pnoise: freq = 54.12 kHz   (28.9 %), step = 3.998 kHz    (556 m%)
    pnoise: freq = 58.43 kHz   (29.4 %), step = 4.317 kHz    (556 m%)
    pnoise: freq = 63.1 kHz      (30 %), step = 4.662 kHz    (556 m%)
    pnoise: freq = 68.13 kHz   (30.6 %), step = 5.033 kHz    (556 m%)
    pnoise: freq = 73.56 kHz   (31.1 %), step = 5.435 kHz    (556 m%)
    pnoise: freq = 79.43 kHz   (31.7 %), step = 5.869 kHz    (556 m%)
    pnoise: freq = 85.77 kHz   (32.2 %), step = 6.337 kHz    (556 m%)
    pnoise: freq = 92.61 kHz   (32.8 %), step = 6.842 kHz    (556 m%)
    pnoise: freq = 100 kHz     (33.3 %), step = 7.388 kHz    (556 m%)
    pnoise: freq = 108 kHz     (33.9 %), step = 7.978 kHz    (556 m%)
    pnoise: freq = 116.6 kHz   (34.4 %), step = 8.614 kHz    (556 m%)
    pnoise: freq = 125.9 kHz     (35 %), step = 9.301 kHz    (556 m%)
    pnoise: freq = 135.9 kHz   (35.6 %), step = 10.04 kHz    (556 m%)
    pnoise: freq = 146.8 kHz   (36.1 %), step = 10.84 kHz    (556 m%)
    pnoise: freq = 158.5 kHz   (36.7 %), step = 11.71 kHz    (556 m%)
    pnoise: freq = 171.1 kHz   (37.2 %), step = 12.64 kHz    (556 m%)
    pnoise: freq = 184.8 kHz   (37.8 %), step = 13.65 kHz    (556 m%)
    pnoise: freq = 199.5 kHz   (38.3 %), step = 14.74 kHz    (556 m%)
    pnoise: freq = 215.4 kHz   (38.9 %), step = 15.92 kHz    (556 m%)
    pnoise: freq = 232.6 kHz   (39.4 %), step = 17.19 kHz    (556 m%)
    pnoise: freq = 251.2 kHz     (40 %), step = 18.56 kHz    (556 m%)
    pnoise: freq = 271.2 kHz   (40.6 %), step = 20.04 kHz    (556 m%)
    pnoise: freq = 292.9 kHz   (41.1 %), step = 21.64 kHz    (556 m%)
    pnoise: freq = 316.2 kHz   (41.7 %), step = 23.36 kHz    (556 m%)
    pnoise: freq = 341.5 kHz   (42.2 %), step = 25.23 kHz    (556 m%)
    pnoise: freq = 368.7 kHz   (42.8 %), step = 27.24 kHz    (556 m%)
    pnoise: freq = 398.1 kHz   (43.3 %), step = 29.41 kHz    (556 m%)
    pnoise: freq = 429.9 kHz   (43.9 %), step = 31.76 kHz    (556 m%)
    pnoise: freq = 464.2 kHz   (44.4 %), step = 34.29 kHz    (556 m%)
    pnoise: freq = 501.2 kHz     (45 %), step = 37.03 kHz    (556 m%)
    pnoise: freq = 541.2 kHz   (45.6 %), step = 39.98 kHz    (556 m%)
    pnoise: freq = 584.3 kHz   (46.1 %), step = 43.17 kHz    (556 m%)
    pnoise: freq = 631 kHz     (46.7 %), step = 46.62 kHz    (556 m%)
    pnoise: freq = 681.3 kHz   (47.2 %), step = 50.33 kHz    (556 m%)
    pnoise: freq = 735.6 kHz   (47.8 %), step = 54.35 kHz    (556 m%)
    pnoise: freq = 794.3 kHz   (48.3 %), step = 58.69 kHz    (556 m%)
    pnoise: freq = 857.7 kHz   (48.9 %), step = 63.37 kHz    (556 m%)
    pnoise: freq = 926.1 kHz   (49.4 %), step = 68.42 kHz    (556 m%)
    pnoise: freq = 1 MHz         (50 %), step = 73.88 kHz    (556 m%)
    pnoise: freq = 1.08 MHz    (50.6 %), step = 79.78 kHz    (556 m%)
    pnoise: freq = 1.166 MHz   (51.1 %), step = 86.14 kHz    (556 m%)
    pnoise: freq = 1.259 MHz   (51.7 %), step = 93.01 kHz    (556 m%)
    pnoise: freq = 1.359 MHz   (52.2 %), step = 100.4 kHz    (556 m%)
    pnoise: freq = 1.468 MHz   (52.8 %), step = 108.4 kHz    (556 m%)
    pnoise: freq = 1.585 MHz   (53.3 %), step = 117.1 kHz    (556 m%)
    pnoise: freq = 1.711 MHz   (53.9 %), step = 126.4 kHz    (556 m%)
    pnoise: freq = 1.848 MHz   (54.4 %), step = 136.5 kHz    (556 m%)
    pnoise: freq = 1.995 MHz     (55 %), step = 147.4 kHz    (556 m%)
    pnoise: freq = 2.154 MHz   (55.6 %), step = 159.2 kHz    (556 m%)
    pnoise: freq = 2.326 MHz   (56.1 %), step = 171.9 kHz    (556 m%)
    pnoise: freq = 2.512 MHz   (56.7 %), step = 185.6 kHz    (556 m%)
    pnoise: freq = 2.712 MHz   (57.2 %), step = 200.4 kHz    (556 m%)
    pnoise: freq = 2.929 MHz   (57.8 %), step = 216.4 kHz    (556 m%)
    pnoise: freq = 3.162 MHz   (58.3 %), step = 233.6 kHz    (556 m%)
    pnoise: freq = 3.415 MHz   (58.9 %), step = 252.3 kHz    (556 m%)
    pnoise: freq = 3.687 MHz   (59.4 %), step = 272.4 kHz    (556 m%)
    pnoise: freq = 3.981 MHz     (60 %), step = 294.1 kHz    (556 m%)
    pnoise: freq = 4.299 MHz   (60.6 %), step = 317.6 kHz    (556 m%)
    pnoise: freq = 4.642 MHz   (61.1 %), step = 342.9 kHz    (556 m%)
    pnoise: freq = 5.012 MHz   (61.7 %), step = 370.3 kHz    (556 m%)
    pnoise: freq = 5.412 MHz   (62.2 %), step = 399.8 kHz    (556 m%)
    pnoise: freq = 5.843 MHz   (62.8 %), step = 431.7 kHz    (556 m%)
    pnoise: freq = 6.31 MHz    (63.3 %), step = 466.2 kHz    (556 m%)
    pnoise: freq = 6.813 MHz   (63.9 %), step = 503.3 kHz    (556 m%)
    pnoise: freq = 7.356 MHz   (64.4 %), step = 543.5 kHz    (556 m%)
    pnoise: freq = 7.943 MHz     (65 %), step = 586.9 kHz    (556 m%)
    pnoise: freq = 8.577 MHz   (65.6 %), step = 633.7 kHz    (556 m%)
    pnoise: freq = 9.261 MHz   (66.1 %), step = 684.2 kHz    (556 m%)
    pnoise: freq = 10 MHz      (66.7 %), step = 738.8 kHz    (556 m%)
    pnoise: freq = 10.8 MHz    (67.2 %), step = 797.8 kHz    (556 m%)
    pnoise: freq = 11.66 MHz   (67.8 %), step = 861.4 kHz    (556 m%)
    pnoise: freq = 12.59 MHz   (68.3 %), step = 930.1 kHz    (556 m%)
    pnoise: freq = 13.59 MHz   (68.9 %), step = 1.004 MHz    (556 m%)
    pnoise: freq = 14.68 MHz   (69.4 %), step = 1.084 MHz    (556 m%)
    pnoise: freq = 15.85 MHz     (70 %), step = 1.171 MHz    (556 m%)
    pnoise: freq = 17.11 MHz   (70.6 %), step = 1.264 MHz    (556 m%)
    pnoise: freq = 18.48 MHz   (71.1 %), step = 1.365 MHz    (556 m%)
    pnoise: freq = 19.95 MHz   (71.7 %), step = 1.474 MHz    (556 m%)
    pnoise: freq = 21.54 MHz   (72.2 %), step = 1.592 MHz    (556 m%)
    pnoise: freq = 23.26 MHz   (72.8 %), step = 1.719 MHz    (556 m%)
    pnoise: freq = 25.12 MHz   (73.3 %), step = 1.856 MHz    (556 m%)
    pnoise: freq = 27.12 MHz   (73.9 %), step = 2.004 MHz    (556 m%)
    pnoise: freq = 29.29 MHz   (74.4 %), step = 2.164 MHz    (556 m%)
    pnoise: freq = 31.62 MHz     (75 %), step = 2.336 MHz    (556 m%)
    pnoise: freq = 34.15 MHz   (75.6 %), step = 2.523 MHz    (556 m%)
    pnoise: freq = 36.87 MHz   (76.1 %), step = 2.724 MHz    (556 m%)
    pnoise: freq = 39.81 MHz   (76.7 %), step = 2.941 MHz    (556 m%)
    pnoise: freq = 42.99 MHz   (77.2 %), step = 3.176 MHz    (556 m%)
    pnoise: freq = 46.42 MHz   (77.8 %), step = 3.429 MHz    (556 m%)
    pnoise: freq = 50.12 MHz   (78.3 %), step = 3.703 MHz    (556 m%)
    pnoise: freq = 54.12 MHz   (78.9 %), step = 3.998 MHz    (556 m%)
    pnoise: freq = 58.43 MHz   (79.4 %), step = 4.317 MHz    (556 m%)
    pnoise: freq = 63.1 MHz      (80 %), step = 4.662 MHz    (556 m%)
    pnoise: freq = 68.13 MHz   (80.6 %), step = 5.033 MHz    (556 m%)
    pnoise: freq = 73.56 MHz   (81.1 %), step = 5.435 MHz    (556 m%)
    pnoise: freq = 79.43 MHz   (81.7 %), step = 5.869 MHz    (556 m%)
    pnoise: freq = 85.77 MHz   (82.2 %), step = 6.337 MHz    (556 m%)
    pnoise: freq = 92.61 MHz   (82.8 %), step = 6.842 MHz    (556 m%)
    pnoise: freq = 100 MHz     (83.3 %), step = 7.388 MHz    (556 m%)
    pnoise: freq = 108 MHz     (83.9 %), step = 7.978 MHz    (556 m%)
    pnoise: freq = 116.6 MHz   (84.4 %), step = 8.614 MHz    (556 m%)
    pnoise: freq = 125.9 MHz     (85 %), step = 9.301 MHz    (556 m%)
    pnoise: freq = 135.9 MHz   (85.6 %), step = 10.04 MHz    (556 m%)
    pnoise: freq = 146.8 MHz   (86.1 %), step = 10.84 MHz    (556 m%)
    pnoise: freq = 158.5 MHz   (86.7 %), step = 11.71 MHz    (556 m%)
    pnoise: freq = 171.1 MHz   (87.2 %), step = 12.64 MHz    (556 m%)
    pnoise: freq = 184.8 MHz   (87.8 %), step = 13.65 MHz    (556 m%)
    pnoise: freq = 199.5 MHz   (88.3 %), step = 14.74 MHz    (556 m%)
    pnoise: freq = 215.4 MHz   (88.9 %), step = 15.92 MHz    (556 m%)
    pnoise: freq = 232.6 MHz   (89.4 %), step = 17.19 MHz    (556 m%)
    pnoise: freq = 251.2 MHz     (90 %), step = 18.56 MHz    (556 m%)
    pnoise: freq = 271.2 MHz   (90.6 %), step = 20.04 MHz    (556 m%)
    pnoise: freq = 292.9 MHz   (91.1 %), step = 21.64 MHz    (556 m%)
    pnoise: freq = 316.2 MHz   (91.7 %), step = 23.36 MHz    (556 m%)
    pnoise: freq = 341.5 MHz   (92.2 %), step = 25.23 MHz    (556 m%)
    pnoise: freq = 368.7 MHz   (92.8 %), step = 27.24 MHz    (556 m%)
    pnoise: freq = 398.1 MHz   (93.3 %), step = 29.41 MHz    (556 m%)
    pnoise: freq = 429.9 MHz   (93.9 %), step = 31.76 MHz    (556 m%)
    pnoise: freq = 464.2 MHz   (94.4 %), step = 34.29 MHz    (556 m%)
    pnoise: freq = 501.2 MHz     (95 %), step = 37.03 MHz    (556 m%)
    pnoise: freq = 541.2 MHz   (95.6 %), step = 39.98 MHz    (556 m%)
    pnoise: freq = 584.3 MHz   (96.1 %), step = 43.17 MHz    (556 m%)
    pnoise: freq = 631 MHz     (96.7 %), step = 46.62 MHz    (556 m%)
    pnoise: freq = 681.3 MHz   (97.2 %), step = 50.33 MHz    (556 m%)
    pnoise: freq = 735.6 MHz   (97.8 %), step = 54.35 MHz    (556 m%)
    pnoise: freq = 794.3 MHz   (98.3 %), step = 58.69 MHz    (556 m%)
    pnoise: freq = 857.7 MHz   (98.9 %), step = 63.37 MHz    (556 m%)
    pnoise: freq = 926.1 MHz   (99.4 %), step = 68.42 MHz    (556 m%)
    pnoise: freq = 1 GHz        (100 %), step = 73.88 MHz    (556 m%)
Total time required for pnoise analysis `pnoise': CPU = 13.8499 s, elapsed = 13.8768 s.
Time accumulated: CPU = 11.3975 ks (3h 9m 57s), elapsed = 11.4078 ks (3h 10m 8s).
Peak resident memory used = 88.7 Mbytes.
designParamVals: writing netlist parameters to rawfile.
Spectre received SIGTERM.
Killed by user.
Aggregate audit (10:02:41 AM, Fri Apr 15, 2016):
Time used: CPU = 11.4 ks (3h 9m 58s), elapsed = 25.9 ks (7h 11m 55s), util. = 44%.
Time spent in licensing: elapsed = 720 ms.
Peak memory used = 88.7 Mbytes.
Simulation started at: 2:50:46 AM, Fri Apr 15, 2016, ended at: 10:02:41 AM, Fri Apr 15, 2016, with elapsed time (wall clock): 25.9 ks (7h 11m 55s).
spectre completes with 0 errors, 12 warnings, and 20 notices.
I would just like to know how to confirm if the pss/pnoise results are correct
I have attached the spectre.out file.
I intentionally ran it for a tstab of 100 us.
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.2.0.510.isr18 32bit -- 7 Mar 2011
It seems that PSS can converge without any problem.
Show me netlist fragments regarding analysis statement and option statement.
Make sure that the following are set correctly
1 - Do you have any filter in the circuit ( may be in LDO/supply ) that can take time to settle. Circuits with huge filter can be sensitive to tstab and results in huge change in pnoise
2 - If you are using spectre for running simulations, increase the reltol to 1e-5 and run in conservative
Reactions: iVenky
    iVenky
