karkip
Junior Member level 1
Hello,
I m working on a project where a relay is used to cut off input of a power supply. Just basic switching ON and OFF of power supply using relay.
In some cases, i found the relay got stuck in closed position. After opening the relay, i found contacts got welded. Not just stuck, but actually welded.
I m assuming this can be the cause of surge current, so trying to figure out how can we avoid this.
Possible solution , i m assuming a RC Snubber or NTC. please suggest what should i use
