Adraen
Newbie level 5
Hi there,
I am currently working on a project with an STM32 and a TI Ethernet Phy. The main point is for the Phy to work a 50MHz CMOS oscillator needs to be used.
I don't have many problems soldering surface mount components in QFP packages, but every single surface mount oscillator i've found don't expose their pins such as this one : https://uk.farnell.com/abracon/ase-...rch=Featured New Products&MER=i-9b10-00002068
The soldering of such oscillator is quite hard without an oven/heat gun and I've been looking for oscillator with leeds but couldn't find any.
So the question is does any one know if and were we can buy oscillator with leeds or an easy method to solder such oscillator ?
P.S: I'm aware of the through holes oscillator but if all the component have to be on the same side then a via is required and most ICs say not to put vias on the clock track. (also most of the time they are much larger than surface mount ones)
Cheers !
Cheers !
