sun55, sun57 what is differences in HSpice 2002 pack
dd2001
Full Member level 4
Full Member level 4
Hmmm,
HSpice 2002 come with 2 set with different name, like hspice2002.sun55.tar, another is hspice2002.sun57.tar,
what is differ? anyone can explain?
thanks
sun55 is refering to 32-bit Solaris 2.5.x while sun57 refers to 32/64-bit Solaris 7. In the newer version of hspice, it has sun58 for Solaris 8 instead of sun57.
HSpice2002 problems on Blade 100
Hi, I install HSPice2002 into Blade 100 and successfuly. However, when I run awaves, it always looking for sun55 folder, not sun57 folder, and report errot: awaves not found.
How to fix this problem?
What's your exact solaris version, 2.5 or 2.7? Basically, hspice detect machine's platform by using the program called "get_arch" in $hsp_dir/bin. It seem you are using solaris 2.5 then hspice has found that and require program from directory sun55. If this my guess is true, delete your old sun57 dir and unpack sun55 instead.
Anyway, you can try to make a symbolic link from sun57 to be sun55 and try using the program from sun57 dir. I'm not sure it can work but it's worth to try.
I think sun57's lib is change ,so you
may need some patch from sun,if not
have may not run .
have may not run .
have may not run .
hspice2002.sun55.tar, is for solaris 2.5 hspice2002.sun57.tar, is for solaris 2.7,
Because Solaris 2.5 differ from solaris 2.7, their pathes are different.
