quaternion
Full Member level 4
- Joined
- Nov 12, 2006
- Messages
- 212
- Helped
- 17
- Reputation
- 34
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Cairo , Egypt
- Activity points
- 2,828
I am new in the field of transmitting and receiving.
The transmitter is a wireless one.
It is a part of a project and not stand alone one and so minimizing complexity and cost is a must. It is used as a control for a semi on-off operation.It is contained in a device (also under design and can be changed) that operates with a PIC micro-controller that checks for a secret code and if the code is right control is enabled,and the Tx transmit signals that control the on-off operation which is also controlled by a PIC µC(i.e. a Rx give the info to the PIC and the PIC controls the operation ).Noting that there are other work in the same project that i didn't talk about so the design needed to be less complex as I said before.Also noting that the PICs are small ones that are used in normal control applications.
I work at 40MHz carrier. As a start I think to transmit the digital info as ASK(amplitude shift keying) but I face some problems that make me to rethink about the modulation type to be used.Also the transmitter and its PIC info source are wanted to operate with a DC source in the range of 9 to 12 V (is this sufficient knowing that the transmitter operating range is no more than 20 meters).Also I decided to use a class B power amplifier to drive the antenna, which is chosen to be a normal loop antenna (coil around a ferrite rod that is used for FM detection).
Which modulation type is recommended in this case and if a suitable IC for modulation and mixing is available please I need its number,also any recommended IC's or implementations.
Many thanks in advance.
