Suggestions for a SLA battery charger
SLA battery charger
this charger generate a lot of heat. but it simple.
SMPS on LM2673(for example) working better.
SLA battery charger
yes very good one. I tried it.
Re: SLA battery charger
thank you ppl for the replies:D
as this circuit doesn't have automatic cutoff, is it ok if i leave the charger connected ALWAYS.
or can you please suggest a circuit with automatic cutoff
:D
a battery must be charged with 1/10 of its AH value
so18 divided by 10 comes to 1.8 amps
LM317 has a 1.5 amps output so it is not advisable to use this circuit as it will run overheated and fail
better to use the LM350 circuit which has a 3 amps rating
:D
Use stend-by mode of charging. This way you can leave the charger connected ALWAYS
try this circuit, it will float charge the battery also
SLA battery charger
These are from Tony Van Roon's site. His circuits are usually quite reliable:
http://www.sentex.ca/~mec1995/gadgets/labc2.htm
Hope this helps.
Tahmid.
