shashipoddar
Member level 2
I have coded this in my way and would like to have your suggestion if it is correct or not as i am unable to verify the same.
Ref:
A. Beghdadi and A. L. Negrate, “Contrast enhancement technique based on local detection of edges,” Comput. Vis. Graph. Image Process., vol. 46, no. 2, pp. 162–174, May 1989.
The easier representation of the below algorithm is also presented in page no. 7/9 of this paper. https://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=5957283&tag=1
First of all we calculate c(i, j) for each pixel of an image I, given by equation below.
c(i,j)=|I(i,j)-E(i,j)|/|I(i,j)+E(i,j)| (18) Where the mean edge gray level is
e(i,j)=∑ g(k,l)x(k,l)/ ∑ g(k,l)
The summation is done for (k,l) being an element of N(i,j). N(i,j) is the set of all neighboring pixels of pixel(i,j) and g(k,l) is the edge value at pixel (k,l). Without loss of generality, 3 X 3 neighborhood is employed, and g(k,l) is estimated using the sobel operators.
The EBCM for image considered is
EBCM= ∑ ∑ c(i,j)/(H*W); where the summation is done for i=1:H, j=1:W.
I am attaching my code. Kindly let me know if i need to change something. I have purposely normalized the image initially so that it is easy to use.
My code:
function EB=EBCM(I_prop1)
[m,n]=size(I_prop1);
h_sob=fspecial('sobel');
I_prop1_norm=double(I_prop1./255);
I_filt_norm=imfilter(I_prop1_norm,h_sob,'replicate');
gij_xij=(I_prop1_norm).*(I_filt_norm);
h_avg=fspecial('average'); %%%default size is 3 by 3
I_filt_avg=imfilter(I_filt_norm,h_avg,'replicate');
gij_xij_avg=imfilter(gij_xij,h_avg,'replicate');
eij=(gij_xij_avg./(I_filt_avg+0.0001));
cij=abs(I_prop1_norm-eij)./abs(I_prop1_norm+eij+0.0001);
cij_u=sum(sum(uint8(round(cij*255))));
EB=cij_u/(m*n); end
Plz let me know if it is worngly implemented
Thanks and regards
Ref:
My code:
EB=cij_u/(m*n); end
Thanks and regards
