Suggestion Regarding Bottle Cap Open Close Sensor
sakibnaz
Full Member level 3
Full Member level 3
Hi All.
I have a project where I need to make a Bottle Cap Sensor which will Alert when the Cap is open. Can anyone advice whats the best way to do it. I thought about IR Tx-Rx based Proximity but it will consume more power where my project needs low power consumption. Also the bottle will be glass made transparent so I can not use LDR to detect light to consider Cap is open :(
Looking forward advice.
Thank you.
if the cap is metallic , will inductive proximity sensor suitable in your environment ?
some things to think about:
Define open and close on the cap?
what sort of cap?
What is the cap made of? is it screw type/push in/cork/flip off?
resealable?
when open - is any part if the cap still on the bottle? Or is the cap totally removed?
