roofingboom
Member level 4
I am looking for sugestions of a suitable chip for a 5 and 3.3v power supply from either a 12 or 24 volt battery. problem is i must survive starter dip which is about 3 volts for 80ms and then 6 volts while the starter is cranking.
I really do not want to use a flyback in this situation. I would like to use a buck boost so i am looking for suggestions please!
thanks
the output will be 3 amps for 3.3v and the 5 volts will only use like 500mA max. i was thinking of a buck boost to 3.3v and then boosting 3.3v to 5 volts since i will not be using much current at 5 votls.
let me know what you guys think
THanks
thanks
THanks
