Suggest Me Linux Based Board
Code Warrior
Full Member level 4
Full Member level 4
I am look out for Linux based board like Raspbbery Pi. I used RP but it doesn't have VGA out put, SATA port and 1GHz processor.
Is there any linux based board available with following specs.
1GHz Processor.
1GB RAM
VGA Output.
SATA Connector.
USB Port X 2 or more.
etc.
Please suggest me and give me links.
Bye
Greetings,
There are many boards based on linux, Here's one : **broken link removed**
For VGA you will need plug in board in this case.
Good Luck
hello
first, for vga u need hdmi to vga plug.
the only, that i know of, sata equipped bord is cubieboard from http://cubieboard.org/. or use usb for hard drives.
if u wont to find more, google.
8)
