Suggest me ICs for a frequency modulation synthesizer
Learner
Full Member level 2
Full Member level 2
Area 621.xxx
FM monolithic IC??
Hi guys,
I am looking to build a frequency modulation synthesizer and was wondering if anything could suggest any IC for doing this?
What I would like to do is actually to use this as a pitch shifter eg. input an audio signal from one end and a frequency of 2 hz, 4 hz etc... on the other in order to shift up the frequency.
I have found signal generator chip such as the Max038 and the XR2206, does anyone have experience with these chips, thoughts?
Are there any other alternatives besides these?
Thanks!
Re: FM monolithic IC??
From Maxim you can get free samples, but I would go for EXAR. They have more experience designing function generators.
I don’t have idea about other function generators, at these low prices.
Hello
You can go for MAX038, its a good choice also.
Regards
